Complete Brake System Upgrade Options?
Old Jul 12, 2020 | 11:02 AM
PUNISHER VETTE's Avatar
PUNISHER VETTE
Default Complete Brake System Upgrade Options?
After years away from my '69 LS1 restomod due to life getting in the way I may have time this summer for one project.
Every time I get in to move the vette around the shed I have no brakes. No fluid under the car so not sure what's the issue. It doesn't matter as I'd like an upgrade for future auto X or just safer/reliable/performance braking.
It's currently manual(no booster). I see willwood mentioned a lot but never saw a complete kit if one exists. What are my options? Budget, all out, smart values? all opinions welcome as I've been away too long to know any better.
I did replace the brake lines when i had the body off the frame so I know those aren't rusty at least.
Master cylinder with proportioning valve built into it?
Master with a remote reservoir?
Are there good upgrades to power brakes if that makes a big difference?
I plan on getting larger rims/tires so I'm not sure if brakes should wait till after that so I can size them properly?
Old Jul 12, 2020 | 12:20 PM
carriljc's Avatar
carriljc
I got my wilwood kit from van steel like 8 years ago. haven't had any problems since. it was on a group buy on this forum. haven't seen another sale since, but here is some info. they've been great for me.
http://www.vansteel.com/index.cfm?fu...&subgroup=3040
Old Jul 13, 2020 | 07:00 AM
terrys6t8roadster's Avatar
terrys6t8roadster
The 6t8 got the full Wilwood treatment, slotted rotors, aluminum caliphers, master cylinder, stainless flex brake lines [all 5] and adjustable porportioning valve. Manual brakes are great. T
Old Jul 13, 2020 | 07:07 AM
grumman41's Avatar
grumman41
Unless you plan on racing your vette maybe rebuild the stock brakes. I’m pretty picky about brakes and like the feel of my LS 5 brakes.
Old Jul 13, 2020 | 07:20 AM
Rescue Rogers's Avatar
Rescue Rogers
Is my vette stock?? HAHA
2016 C3 of Year Finalist
Manual or power you should have a pedal when not running. Most likely just a lot of air in your system. You can use the stock calipers and have great brakes with ceramic pads....if you need more you can add slotted discs. If you upgrade the motor so you increase the speed dramatically between the turns then you can go larger, it’s just a huge expense if you’re not going to use it all the time. I would upgrade what you have and if you need more, then sell what you have
check the rims for fluid, my leak was small and would drip on the rim then wrap around under the tire. I wouldn’t see it until I moved the car
Old Jul 13, 2020 | 07:48 AM
PUNISHER VETTE
I'm able to vacuum bleed and get great pedal feel...then a few months later when I need to move it I have very little.
I can't imagine it's an air bubble that isn't being bled out. Unless it's an issue with the master cylinder not bleeding correctly. Or it's just a leak that I haven't found. :/
Old Jul 13, 2020 | 09:09 AM
Rescue Rogers
It could be leaking out of the plunger in the master and onto the firewall, inside the car behind the carpet or on the engine side, sounds really slow
Old Jul 13, 2020 | 12:47 PM
Big2Bird's Avatar
Big2Bird
Yes
Old Jul 13, 2020 | 10:22 PM
vette427-sbc's Avatar
vette427-sbc
The stock brakes are beyond adequate. They work great for autocross, if you’re road racing, then it’s worth upgrading to something that can shed the heat better. Wilwood does make a whole kit that bolts on If you still want to upgrade.
Old Jul 14, 2020 | 04:36 PM
jb78L-82's Avatar
jb78L-82
Originally Posted by vette427-sbc
the stock brakes are beyond adequate. They work great for autocross, if you’re road racing, then it’s worth upgrading to something that can shed the heat better. Wilwood does make a whole kit that bolts on if you still want to upgrade.
this^^^^^^^^^^^!
Old Jul 14, 2020 | 09:59 PM
PUNISHER VETTE
Thanks for the input. I'll keep trying to find the leak and fix the current brakes then. I can always upgrade later if needed.
I have no interior currently so I should be able to spot a master cylinder leak.
Can I lose pedal feel without losing fluid?
Old Jul 14, 2020 | 10:22 PM
Big2Bird's Avatar
Big2Bird
I would look at the master.
To Complete Brake System Upgrade Options?
