A/F mixture / Timing Relationship?
Old Jul 16, 2020 | 09:44 AM
7T1vette's Avatar
7T1vette
All we can do is explain to you the BEST way to adjust your carb. It is YOUR choice as to which method you use. If your method actually worked well, I don't think you would be asking for assistance on this Forum. Either way, I wish you luck in getting your engine running well.
Old Jul 16, 2020 | 11:57 AM
MelWff's Avatar
MelWff
I know I'll catch hell for saying this, I have been adjusting idle speed using a tachometer since around 1968, never used a vacuum gauge.
Set your idle speed screw to whatever speed you want.
Then turn either idle mixture screw in a 1/4 turn, if the idle drops turn back out a 1/4 turn.
Then turn the other idle screw in a 1/4 turn, if the idle drops turn back out a 1/4 turn.
Continue doing this until both screws have produced that drop in idle and you have turned them back out 1/4 turn once you hit the idle drop.
Readjust your idle speed if necessary.
Reconfirm both screws cause a drop when turned in a 1/4 turn.
Old Jul 16, 2020 | 12:54 PM
BarryB72's Avatar
BarryB72
Thanks guys. Like I mentioned, I noticed that as the idle became more rich both RPMs and vacuum increased because I had both tach and vacuum gauge hooked up at the same time so they work in accordance.
I just have to cut it off at the point it floods.
I went through the 3 and 4 turn area today with RPM at 850 which is where Lars said he sets it and I settled on a setting.
Old Jul 16, 2020 | 01:33 PM
MelWff's Avatar
MelWff
The 3 or 4 turn is where he starts and then turns in to obtain lean drop and backs out. You don't leave it at 3 or 4 turns without adjusting it further.
Old Jul 16, 2020 | 01:54 PM
BarryB72's Avatar
BarryB72
I just mentioned 3-4 as the range I focused on because it flooded at 4 and it sputtered at WOT at 2.5.
I went through every 1/8 th of a turn between 3 and 4 and settled on 3.5 then tried what you could call 1/16 of a turn above and below 3.5 and ended up at what amounts to 3 and 9/16 turns.
Old Jul 16, 2020 | 04:23 PM
MelWff's Avatar
MelWff
Since you are only adjusting idle mixture the fact that you had a problem at WOT points to some other issue with the carburetor.
Old Jul 16, 2020 | 08:40 PM
BarryB72's Avatar
BarryB72
Sorry. Forgot to say that only happened in 1st gear when I floored it off a dead stop. Maybe wot is the wrong term.
Old Jul 17, 2020 | 12:00 PM
MelWff's Avatar
MelWff
Seems to me you are describing an accelerator pump problem that you are trying to remedy by richening the idle mixture.
Old Jul 17, 2020 | 01:34 PM
BarryB72's Avatar
BarryB72
What's your favorite way to test that?
I do see hesitation on acceleration is also a sign of a lean mixture.
Old Jul 17, 2020 | 02:47 PM
MelWff's Avatar
MelWff
With the engine off, open the throttle by hand and watch the pump arm movement and you should observe two strong shots of gasoline without any hesitation, one in each primary throat.
Old Jul 18, 2020 | 10:17 AM
BarryB72's Avatar
BarryB72
That checked out fine. I thought I could always hear the squirts when I pushed the pedal to set it up to start - just never did it by hand.
And it really likes the set up where I have it.
No issues any where and it almost seems fast.
