Quadrajets for CA smog
Old Jul 14, 2020 | 09:42 AM
igilbert91's Avatar
igilbert91
Default Quadrajets for CA smog
Hey Everyone,
Proud new owner of a 79 L-48 corvette with all the emissions bells & whistles. The car came with a commercially remanufactured quadrajet, of which, Lars has taught me this carb is nothing more than a paper weight. I am now in the process of trying to find an original quadrajet core. My question: will any date appropriate quadrajet from a Chevy have the proper provisions for all of the emissions components? Or will I be stuck looking for the castings with a “5” noting it’s a CA carb?
Thanks!
Ian
Old Jul 14, 2020 | 11:01 PM
Shark Racer's Avatar
Shark Racer
Originally Posted by igilbert91
Hey Everyone,
Thanks!
Ian
Most 79 Corvette / Camaro carbs should work fine. Is your car an automatic? Most important is having the correct throttle linkage if you have an auto.
Old Jul 14, 2020 | 11:02 PM
Shark Racer
Which section of CA are you in?
Old Jul 14, 2020 | 11:27 PM
igilbert91's Avatar
igilbert91
Automatic. And I’m in Pittsburg. Spent 6 years in SJ/Campbell before this
So I need to find castings that end with even numbers? Good guidance. Thanks!
Old Jul 15, 2020 | 12:06 AM
Shark Racer
I may have some worthwhile cores, but I’ve gotten rid of most of my remaining stuff.
Is your carburetor gone?
Old Jul 15, 2020 | 12:11 AM
igilbert91's Avatar
igilbert91
Previous owner left me with two remanufactured Q-jets. Probably both paper weights. I’d be open to hearing about what you still have.
Old Jul 16, 2020 | 10:36 AM
7T1vette's Avatar
7T1vette
They may, or may not, be badly remanufactured. The big reman outfits just have mass disassembly of carburetors, and then mass assembly of them from whatever parts would appear to fit together. Some of the smaller outfits may actually rebuild individual carbs. But there is no way to know, unless you are and expert or you send it to one.
If you already have the carb, you could buy a rebuild kit for the part number stamped into the left-rear corner of the main body and give it your 'best shot' at a useful life. If you adjust the carb per the instructions and on the running engin,e and it works well, great. If it doesn't you are back to 'square one', but you gave it a good try and you learned a lot about the Q-jet carb.
Old Jul 16, 2020 | 02:21 PM
Shark Racer
This is what I was thinking. I'd be willing to take a look at the carbs and see how far off they are.
Some things, like air bleeds and idle fuel tubes, can be replaced with a little bit of work.
I'll try to get to my boxes of parts this weekend to see if I have any left over.
To Quadrajets for CA smog
