81 Vette - Front Driver Side Fluid Leak
Old Jul 14, 2020 | 04:48 PM
gfrank5's Avatar
gfrank5
4th Gear
Default 81 Vette - Front Driver Side Fluid Leak
I've been fighting a rough idle for the last few days and making adjustments on the carb. When it is idling the RPMs pulse between 1200 and 800. Also, the emissions are very strong and burn your eyes. When I turned the engine off, fluid started pouring out of a hose directly behind the driver's side front tire. I am attaching a picture.
First of all, what is the canister that the fluid is leaking from? Is it just a matter of an unplugged hose or something worse?
Thank you,
Fluid leaking from rubber hose under this canister on driver side of car just behind front wheel
Old Jul 14, 2020 | 04:54 PM
MelWff's Avatar
MelWff
That is the evaporative vapor canister.
It's function is to route gasoline vapors from the tank into the carburetor.
It should never have any kind of fluid in it.
Did you smell the fluid to see if it is gasoline?
Do you have the stock air cleaner assembly?
I believe that is a vent that is supposed to obtain air from the air cleaner assembly.
Post #11 in the link below has a diagram.
https://www.corvetteforum.com/forums...gram-help.html
Old Jul 14, 2020 | 05:01 PM
gfrank5's Avatar
gfrank5
4th Gear
Yes, it does smell like gasoline.
Yes, I do have the stock air cleaner assembly.
So what is the cause of this issue?
Thank you for the help.
Old Jul 15, 2020 | 08:46 PM
7T1vette's Avatar
7T1vette
I suspect you have a defective vapor canister and/or you have a failed fuel separator device on the fuel tank. The separator is there to PREVENT liquid fuel from being sent to the vapor canister. You could also have the hoses on the vapor canister or devices in the canister could be allowing fuel to be drawn into it. Investigate those items and see what you find.
Old Jul 17, 2020 | 08:10 AM
GUSTO14's Avatar
GUSTO14
Grant, welcome to the Corvette Forum. You've come to the right place to get all sorts of help and information on your Corvette. A great group of folks here and most are eager to assist you in getting the most out of your Corvette experience.
To get some excellent background information on your Evaporative Emission Control System, check out this link... 1970 to 1982 Corvette Evaporative Emission Control System, EEC or ECS, Repairs
It's a pretty thorough article that will help you to understand what you're dealing with and some tips on how to get it operating as intended.
Save the wave... GUSTO
Old Jul 17, 2020 | 11:55 AM
KenSny's Avatar
KenSny
Nothing connects to that bottom port. That is a vent.
The dripping gas might be that the canister is not being purged.
Easy to check all the stuff between the solenoid valve on top of the canister and the carb/engine lines from there.
To 81 Vette - Front Driver Side Fluid Leak
