Iron Diff Compatibility Question
Old Jul 15, 2020 | 12:20 PM
Mark Riles's Avatar
Mark Riles
Default Iron Diff Compatibility Question
I'm sorry if this has been covered to death I did not find answers to my specific questions in my searches.
Will an iron diff from a '77 bolt to the frame of a '74?
Both cars were factory TH350 cars, both 3.08 cars, and there's going to be a mono spring change using the '77 diff as the year.
Thanks.
Old Jul 15, 2020 | 12:29 PM
MelWff's Avatar
MelWff
It's the same type of differential. didnt change until 1980 to aluminum.
They both use the 2.25" width rear spring.
Old Jul 15, 2020 | 12:40 PM
Mark Riles's Avatar
Mark Riles
Thank you. The only thing I was concerned with was the cross member bolt pattern.
Were there different cover designs? Not that it matters, because the mono spring was bought for a '77.
Old Jul 16, 2020 | 07:35 AM
Rescue Rogers's Avatar
Rescue Rogers
Is my vette stock?? HAHA
2016 C3 of Year Finalist
Pretty sure you can use a diff from 64 to 77. Apparently there is strength differences if you race or manhandle them too much. The 64 to 66 had week clutch housing, and as I understand it the 69 to 70 something had a stronger case. There’s some threads on it if you want to get deep in the weeds. You’ll be fine
Old Jul 16, 2020 | 10:34 AM
GUSTO14's Avatar
GUSTO14
Mark, just do a search on the C3 TECH/PERFORMANCE Forum for GTR1999. You will find the answer to just about any question you might have regarding the rear suspension of the C2-C3 Corvettes. You may need to do a bit of reading to find the answer to a specific question, but you'll learn a lot along the way.
Gary Ramadi's (GTR1999) answers are filled with technical data and spec's so the reading is always informative. You can also send him a PM if you have difficulty finding a specific answer or are confused by a post. He's exceptionally detailed and knowledgeable regarding these cars and a great example of what makes the Corvette Forum such a terrific place to visit.
Here's just one post I found with some great info regarding the '77 rear differential in an answer Gary provided to a members question... https://www.corvetteforum.com/forums...d-rebuild.html
Good luck... GUSTO
To Iron Diff Compatibility Question
