Hello. I was wondering about the clutch cross shaft on my 69. Under the car and looking at different things I noticed that the cross shaft has some lateral movement when you try and check it. Both ends are tight and secure. Just wondered if there should be any lateral play, about 1/4" in the shaft. I do have some vibration in the clutch pedal and wondered if this looseness could be getting vibration from the motor and passing it on thru the clutch linkage somehow? just wondering. Thanks and take care.
Hi and thanks for the quick reply and suggestion.Yes the nut on the frame end is tight and the stud? on the engine side is also good and tight .Thanks again.
There has to be some compliance to accommodate engine movement. Are you sure that isn't what you are feeling? If that nut is tight it doesn't seem that the "z-bar", as that is what it is called, is likely to come off!
As to your vibration, there could be many causes. Do you have all the anti-rattle springs? There are, I believe, two attached to the pushrod to the clutch arm, and one attached to the firewall.
One more thought, there is a grease fitting and the shaft should be full of grease.
Hello and thanks for your reply ignatz. in thinking about it, I think that as you said that there has to be some play to accommodate the movement of the motor and that is what I'm noticing. One more thing to keep an eye on. Take care.
Thank you in advance ,
69 350/300hp
Removing old rusty header side pipe on the drivers side. Removing the Clutch Cross shaft and the dip stick would be sufficient to remove
and install the new header? Or am I dreaming that there's more to it? Sorry , I haven't done this in 45 years. I'm a little rusty also
Thank you
Charlie
Reason: added a couple of words
69 350/300hp
Thank you
Charlie
you probably have to remove spark plugs and be careful with the temperature sender.
