Another brake bleeding question
Old Jul 22, 2020 | 06:27 PM
Duane4238's Avatar
Duane4238
Default Another brake bleeding question
When bleeding the rear calipers, do I bleed the inside first or the outside bleeder first? I don't do this often enough to remember. Thanks.
Duane
Old Jul 22, 2020 | 06:43 PM
sullyman56's Avatar
sullyman56
I bleed the outside ones first.
Old Jul 22, 2020 | 07:33 PM
Peterbuilt's Avatar
Peterbuilt
Always bleed the 'inners' first then the 'outers'.
Old Jul 22, 2020 | 07:47 PM
OH81's Avatar
OH81
1st Gear
Here is a good reference video for bleeding C3 brakes:
Old Jul 22, 2020 | 08:51 PM
sullyman56's Avatar
sullyman56
Oops. I had that backwards.
Old Jul 22, 2020 | 10:18 PM
Bikespace's Avatar
Bikespace
I have two catch bottles, and do both at once with a Motive Pressure Bleeder at the other end.
Old Jul 22, 2020 | 10:49 PM
7T1vette's Avatar
7T1vette
The bleeders get done according to the 'distance from the master cylinder'. Some folks (and GM) start with the farthest away and work toward the M/C. Others (and I) work from the M/C then out to the farthest bleeder. In the case of the rear caliper bleeders, there is only a few inches difference; but your chosen strategy would still apply.
Old Jul 23, 2020 | 06:38 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Bingo.
Old Jul 25, 2020 | 01:05 PM
ctmccloskey's Avatar
ctmccloskey
I used to fight with getting air out of the brake system on my 1968 C3. I then bought a Phoenix Reverse Bleeding system. Now it is much easier as I push the fluid up into the system and it come out of the Master cylinder. I put a catch bucket under the M/C and very carefully keep the fluid from overflowing by using a turkey baster to pull excess from the M/C.
The Phoenix system works very well on the C3's and even better on the C4's or anything with a hydraulic clutch. I have used this tool on my Cessna, my motorcycle and my Corvettes and other family cars. It is one tool really that does make the job easier. This system makes it easy to do the bleeding or just flushing the old fluid out of the system. Pushing air up makes more sense to me than pushing air down in the brake system!
Old Jul 26, 2020 | 11:26 AM
gguillot's Avatar
gguillot
Interesting. I use the Motive pressure bleeder, but this reverse bleeder may be even more convenient. If you don't clamp the Motive Bleeder down perfectly, you end up with a mess of brake fluid under your car, OR if you just pressurize, you have to constantly check the M/C levels to make sure you aren't running low.
Old Jul 26, 2020 | 12:06 PM
Duane4238's Avatar
Duane4238
Thanks for all the suggestions. I finally went with the gravity bleed technique and it worked just fine. Did the inside bleeder first, on the rears. I have a nice firm pedal, now. Thanks, again.
Duane
Old Jul 26, 2020 | 04:13 PM
7T1vette's Avatar
7T1vette
If you drain all of the old, water-laden, nasty brake fluid first, that kind of bleeder would work great. Not thrilled about having to have a 'catch can' under the master cylinder, though.
To Another brake bleeding question
