Headers. Worth it or not?
etc. Long boring list?
THAT is my point.
" But I gain 20% hp."
My answer,
Look at the total cost.
Metal cars radiate heat, and fiberglass cars are more like eskimo coolers, and eat road surface air.
That 30 hp, or whatever, takes the under hood temp even hotter.
Go ahead, make the arguement of worth.
Bracketcar. Hell ya. Road car, yup.
Street car, DD, PRO TOURING., I say ,
Its very expensive to do it correctly, or very expensive if you don't.
So, think about that.
JIM
yes I've had them on other cars.
Yes I've had my 77 on the local racetrack a number of times. Yes I more than keep up.
I've always wondered on a street car, just how big of advantage headers really are. At RPM's that we actually drive at.
Also would love to see dyno sheets from standard manifolds to 2 and a half inch manifolds and long tube and short tube headers all on the same engine with the same exhaust behind the manifolds and or headers.
I would truly be interested in this kind of info.
JIM
You addressed all the issues like wrap, etc.
Never wrapped a single header in my life.......if ceramic coated inside and out, with proper timing settings......no issues.
Run studs and tighten the **** out of them with serrated flange nuts.......never mess with it again.
Every Vette on the planet should have headers IMHO.......especially Big Blocks and LT-1's or L-79's......
I personally would not own a Vette without them.....
Jebby
Fast forward to my current engine swap project. I'll be running a set of Stan's Tri-Y headers (ceramic coated). These are very nice headers. Pricey but I'm glad I went down this road. For those that missed the thread, I worked with Stan himself to modify the Tri-Y header to work with the Borgeson steering system. After a couple of iterations, Stan tweaked the design perfectly and now those headers will fit with either the Borgeson or stock steering system and will also work with either straight or angled plug heads. Even though the new headers are ceramic coated, I've made a few heat shields, and installed high temp wire sleeves over vulnerable wiring. I'm betting I will vote these headers as worth it once I get the car running again.
DC
no special plug wires routing or socks on them, no special manifold gaskets, NGK plugs, not shorties. I’ve had zero issues with them.
exhaust that is routed out the side making working on anything under the car far more accessible. Also eliminating a source of floor heat. I can access all the plugs easily from above.
for me, headers has made things much easier, not harder.
