Headers. Worth it or not?
Old Jul 25, 2020 | 09:41 PM
4-vettes's Avatar
4-vettes
Cruise-In VIII Veteran
Originally Posted by nyciti
Also depends on the engine and build....I damn sure not going to run cast manifolds on my SC 383, talk about killing HP!! Good headers done right are not an issue...if you have a little cabin heat install some AC problem solved
but? How much HP??? And where?
Old Jul 25, 2020 | 10:52 PM
Big2Bird's Avatar
Big2Bird
So on the friendly dyno in the air conditioned room, they add 40 HP.
Jamb then in an insulated engine compartment and bake everything at 300 degrees for maybe 30HP, while cooking the intake air. Wonder what that takes away?
So maybe 20 HP net gain after sucking hot air, while either adding cost or weight or?
The gain versus the toaster oven effect.
Old Jul 25, 2020 | 10:57 PM
Big2Bird's Avatar
Big2Bird
Originally Posted by REELAV8R
I can speak to side pipe headers. I got mine ceramic coated first, used stage 8 locking header bolts to keep bolts from backing out and never looked back.
no special plug wires routing or socks on them, no special manifold gaskets, NGK plugs, not shorties. I’ve had zero issues with them.
exhaust that is routed out the side making working on anything under the car far more accessible. Also eliminating a source of floor heat. I can access all the plugs easily from above.
for me, headers has made things much easier, not harder.
Side pipes with hookers wrapped are not bad. People don't like them wrapped, but race cars do, and done well, it shows it's serious, like a race car.
If you want a race car look, you have to do some race car stuff, (Except red boxes).
Old Jul 26, 2020 | 04:07 AM
hdeyong's Avatar
hdeyong
Horsepower is fine, but where I live, (twisty, hilly roads), I want torque, especially at lower RPM's.
I'll probably rebuild the engine in December, and will build it for torque, probably keeping the rams horns. I think, for torque, below 3,500 RPM, there would be almost no gain with headers.
Old Jul 26, 2020 | 05:27 AM
4-vettes's Avatar
4-vettes
And that is why I keep asking the question, how much power and where. 20 HP at 6,000 RPM means little to me, but 50 Foot pounds tourqe at 2,000 RPM would mean bucket loads.
so, has anyone really dyno'd one engine, no changes but exhaust, stock 2inch manifolds, 2 and a half inch manifolds and short and long tube headers. Peek HP at 6,000 might be of interest to a drag racer. But on a short track or the street, tourqe at lower RPM 's is King.
if I'm to give up all my stock ign shielding and head shields. I would like to think there's a good enough reason.
high RPM power from my over 40 year old car means nothing to me.
Old Jul 26, 2020 | 11:13 AM
Big Block Dave's Avatar
Big Block Dave
A few years back forum member Zwede had posted several dyno runs on his relatively stock LS5. A set of long tube headers made a HUGE gain vs stock manifolds. I want to say around 50 hp. Thats a gain that would be impossible to avoid noticing.
Old Jul 26, 2020 | 01:08 PM
Jason Staley's Avatar
Jason Staley
Cruise-In III Veteran
I don't have a dyno run for when I had ram horn manifolds with dual exhaust on my ZZ4, but that engine definitely didn't like old school manifolds at anything above idle. It ran horrible; just wasn't a good combination of exhaust manifold design, exhaust port design, and cam profile. I never could get it tuned so it would run correctly throughout the RPM band. I'm not talking peak HP number, but rather A/F mixture and just good all around running behavior.
When I installed ceramic coated headers the engine responded really well to the exhaust change. I went with the smallest full length header since I wasn't going to be at full throttle all the time, and made sure they accommodated the factory clutch linkage. I had no problems at all installing them, and they've been on the car now for 20 years with no problems. To cure any additional temp in the engine bay that the ceramic didn't prevent, I fabricated a cowl induction system so the engine would be drawing in nice cool outside air.
Old Jul 26, 2020 | 01:23 PM
Rescue Rogers's Avatar
Rescue Rogers
Is my vette stock?? HAHA
2016 C3 of Year Finalist
When you ask where, it depends on the engine build...are we talking stock heads , cam and intake? Then ya, maybe 20hp at the top end, if you start upgrading with an intake , heads with a good cam then you are able to flow more easily into the engine, but if you are plugging the exhaust again you will see it more at the middle and top. If you unplug it with headers you get improved breathing and you get gains at the bottom end...engine masters shows this at times. They did a couple of manifold to header comparisons then later take the same motor and throw a bigger cam in it and it all goes u . BUT THEY EXPLAIN it's all done at wide open throttle so you obviously aren't going to be WOWed with the power your cranking out at idle or cruising though down town...until you see that tuner import at the next light.....blue WRX looking to show of for his friends... BAM Johnny smokes him off the light and the guy gave up about 20 yards down the road...
Old Jul 26, 2020 | 01:33 PM
CSIROCZ's Avatar
CSIROCZ
You do realize you're talking about a Chevy? Magazines have been running these dyno tests for decades. In general, the more power the motor is built for, the more power loss there is from manifolds. And from what I've seen, that difference is across the entire RPM spectrum. I have absolutely seen 40-50 HP loss from manifolds at 3500 RPM on a 500 HP engine. I've also seen only 5-10 HP at low RPM for relatively stock applications. Just do a google search for "headers vs manifolds dyno"...find the application closest to yours.
If all you want is a stock engine to putter around in, then of course you wouldn't (and shouldn't) consider headers. But if you're building a 400-500 HP engine, why would you spend all of that money just to choke it with manifolds? Might as well just build the lower HP engine to start with.
Old Jul 26, 2020 | 03:22 PM
ignatz's Avatar
ignatz
Bystander on my small block with headers:
"Is that a big block?"
So, "worth it?" - absolutely!
Old Jul 26, 2020 | 03:25 PM
Rescue Rogers
With my cam and the headers I get similar questions and surprised looks when I say its just a 327....Then they laugh and say " just a 327" some go on to talk about teenage memories of 327's and how they have become a legend of the past...
Old Jul 26, 2020 | 05:37 PM
Jason Staley
I've had the same comment due to my fabricated valve covers. (Pic was taken prior to my cowl induction setup).
Old Jul 26, 2020 | 07:54 PM
  #33
platinummaker's Avatar
platinummaker
I went with Hedman ceramic headers, used a marine spacer so my plugs fit better, added the woven plug heat protection socks, only had to dent the headers around the idler arm and steering box. My perceived cabin heat increase is negligible. On a 2 hour drive I wear sandals and my feet are comfy. I insulated my fuel lines with heat reflective socks and already had a fuel cooler and a cold air horsepower increase is well worth it to me as the rams horns were pretty much a plug for the way I had my motor setup in the past, with the new cam it’s insane!!
Rescue what is a “marine spacer” please.
Old Jul 26, 2020 | 08:48 PM
  #34
Rescue Rogers
THey are made by Hardine marine, theres other companies that make header flanges for custom pipes that can be used but these are 1/2 inch. I read that were originally used on marine engines for alignment of pipe tube issues. They can be used to solve all sorts of issues from alignment of tubes to valve cover clearance to spark plug clearances. THey are bigger inside diameter but I used square port aluminum gaskets on the motor side and oval on the header side. I used Mr gasket, I bought Taylor cable but they have no seal at the bolts. I measured the ports to figure out which Mr Gaskets I needed
https://www.summitracing.com/search/...ial%3Aaluminum
Sealed really well. I think I will eventually have them aluminum welded up to make them more of a square port to oval port adapter so the flow is better...but it works really well now. I talked to an engineer at headman and head said as long as the lip at t he corner was under a 1/16th it wouldnt be a problem..I forget the exact tolerance but it was right there..
https://www.cpperformance.com/p-1281...ock-chevy.aspx
https://www.hardin-marine.com/p-1281...ock-chevy.aspx
Old Jul 26, 2020 | 09:52 PM
  #35
Big2Bird's Avatar
Big2Bird
I never knew about those. Not a boat guy really.
I had a Hardin Marine shop next to mine for a bit way back when.
Old Jul 26, 2020 | 09:56 PM
  #36
Big2Bird's Avatar
Big2Bird
The guys with headers and big blocks in Vettes have to do it smart, or it just cooks everything.Not enough air. And the A/C condenser pre-heats it for you.
Old Jul 26, 2020 | 09:58 PM
  #37
Big2Bird's Avatar
Big2Bird
The 73 SBC I am working on right now has lots of air space.
To Headers. Worth it or not?
Old Jul 27, 2020 | 10:20 AM
  #38
platinummaker
Thank you. Makes total sense.
Old Jul 27, 2020 | 10:37 AM
  #39
71chimera's Avatar
71chimera
Default Hardin flange
? Remember "Jardine" ? their shop was near you as well.
Old Jul 27, 2020 | 11:12 AM
  #40
Rescue Rogers
I used socket head screws because of the length required and they were drilled for safety wire so they wont loosen up
