I posted about a jumper in the fuse panel in the gauge slot. Upon looking closer, I see another questionable wire.
I haven't been able to get under and take a close look. I am going to remove the driver's seat later today and hopefully get a better look.
Does the circled wire look like it should be there?
eddp, I think yours looks OK.
You're just being too fussy
Oh yeah. I've seen that, and the use of rolled up foil from a pack of cigarettes,
Don't need no damn fuses. Keep the juice flowing until something smokes then you found the problem.
And if you got 50A fuses, then use them if your 10A blows.
Then there were the 2 brothers that had a fuse fail and they decided to stick a .22 bullet in there...temporarily. One of the brothers ended up with a bullet hole in the leg, shortly thereafter.
I had all kinds of fun today. Pulled out the driver's seat and pulled the red jumper and replaced with a 20 amp fuse.
Drove a while and nothing seems to have blown the fuse. We'll see??
