Stuck no run help please on road
Old Aug 20, 2020 | 12:05 PM
  #81
Big2Bird's Avatar
Big2Bird
Have you ever changed the filter sock in the tank?
Hoses on the tank?
Old Aug 20, 2020 | 01:37 PM
  #82
interpon's Avatar
interpon
Hoses on the tank?
no
thank you... only slide 41.. yes sorry long thread debated new one but would miss history..redundant questions..
it runs and flows perfect..when i changed pump the level was lower and it pours out..very weird why sets..warm.. then occasionally does this.. i have no clue if adding gas or waiting another few minutes.. its like OFF on the gas.. it died hard.. dry carb.. not like restriction or anything...
plenty of flow cold running..just this very weird off on issue..new pump flowed like crazy..
Old Aug 20, 2020 | 01:51 PM
  #83
REELAV8R's Avatar
REELAV8R
Is it possible the fuel gauge is inaccurate and it just ran out of fuel?
I have read about fuel tank liner issues causing problems as well as inaccurate fuel indications.
This thread talks about it.
https://www.corvetteforum.com/forums...ner-issue.html
Old Aug 20, 2020 | 01:56 PM
  #84
71 Green 454's Avatar
71 Green 454
Originally Posted by 71chimera
The majority of fuel line degradation usually occurs inside; where the gas is attacking (along w/ whatever other solvents the refiners are including these days).
I agree, ethanol fuel totally ruined my new gas tank and hoses. The hoses at the rear tank connections still looked new, but were eaten up inside and sticky. Replaced fuel tank, sending unit, rubber hoses, S hose, fuel pump and filter. Now I only use ethanol free gas and the tank still looks new inside and hoses are not affected.
Old Aug 20, 2020 | 02:40 PM
  #85
Big2Bird's Avatar
Big2Bird
Originally Posted by interpon
no
That is the symptom.
You drive along, and the sock sucks closed. You sit awhile, and it starts right up after the sock relaxes.
I have seen it twice on Vette runs.
That is why I preach about them
They are all 50 years old.
You can do later ones via the lid.
Remove lid, loosen tank straps, lower a few inches.
Needle nose will get the rubber hoses.
The vapor hose on drivers side, better to drop the tank.
It is was it is.
Old Aug 20, 2020 | 03:42 PM
  #86
71chimera's Avatar
71chimera
still dying of natural causes; change out all aged rubber & sock.
you gave it a heart transplant but its arteries are still blocked
  #87
73racevette's Avatar
73racevette
This sounds like vapor lock to me. Put a phenolic or similar spacer under the carb, my bet is you will be cured.
Old Aug 20, 2020 | 05:17 PM
  #88
REELAV8R's Avatar
REELAV8R
Normally I would say yes, fuel boiling from the carb or vapor lock like symptoms. But The carb has no fuel even after running 2 minutes? The pump should have filled the carb long ago unless the pump is truly vapor locked.
How would heat be related to hoses being decayed. Wouldn't fuel starvation occur regardless of heat? Same with the sock in the tank?
  #89
interpon's Avatar
interpon
E
no sir..plenty of gas..visually and when filling up takes no more than 11 gallons to top...
did the same thing at initial failure replaced fuel pump..spilled a gallon, and ran 50 miles before filling up again
Old Aug 20, 2020 | 05:22 PM
  #90
interpon's Avatar
interpon
It is was it is.
i hate changing stuff i cant find sympton of....dammit
guess no car this weekend (broke a shock too).suppose dropping tank and inspect.....assume this is doable diy?
ill search some threads and read manual..
your saying drop tank not through lid? I have fat hands and 11 gallons of fuel....or do i need to do both?
Old Aug 20, 2020 | 05:36 PM
  #91
Big2Bird's Avatar
Big2Bird
Drain tank.
Remove spare and carrier.
Open lid, unplug sender.
Jack with wood block under tank.
Let her down. Easier with helper.
Wear glassses. Lots of crap in eyes.
Old Aug 20, 2020 | 05:44 PM
  #92
REELAV8R's Avatar
REELAV8R
You need to recreate the situation while at home. Then pull the fuel line and see if the pump is pumping fuel or not. That's what I would try to do first.
Old Aug 20, 2020 | 05:45 PM
  #93
interpon's Avatar
interpon
Drain tank.
ok...starting..
here is best pic i could get
may i ask if sock local or just online? Other stuff ill need?
Old Aug 20, 2020 | 06:04 PM
  #94
interpon's Avatar
interpon
Tasty...
i pulled about 12 out non ethanol 90
Old Aug 20, 2020 | 06:05 PM
  #95
interpon's Avatar
interpon
i wish...not that repeatable i was fine for about 500 miles of a lot of trips
Old Aug 20, 2020 | 06:07 PM
  #96
interpon's Avatar
interpon
Drain tank.
exhaust too?
Old Aug 20, 2020 | 06:09 PM
  #97
Big2Bird's Avatar
Big2Bird
Sock is Rock Auto, but maybe NAPA.
You should have some good Gates fuel line in 3/8" and 5/16". Maybe 6'? of each.
Gasket is reusable if carefull.
To Stuck no run help please on road
Old Aug 20, 2020 | 06:25 PM
  #98
OldCarBum's Avatar
OldCarBum
Next time install a priming ball for a Mercury outboard boat motor so the squeeze ball is in the line just out of the fuel door.
Squeeze the ball and it sucks the fuel for you.
Once the fuel starts flowing, stop squeezing the ball.
Simple and no tasty gas.
[/QUOTE]
Old Aug 20, 2020 | 06:30 PM
  #99
OldCarBum's Avatar
OldCarBum
Did you try swapping the ignition coil for a new one?
When a coil is going bad, they will fail when they warm up, then operate normal once they cool.
Old Aug 20, 2020 | 07:04 PM
  #100
interpon's Avatar
interpon
exactly...this shpuld be interesting
