Cabin heat issue
Old Jul 26, 2020 | 06:43 PM
bubba998's Avatar
bubba998
4th Gear
Default Cabin heat issue
I have a 1975 coupe I just love. (Second C3) I am getting very hot air coming thru the vents ONLY after driving for a while, leaving the vehicle for a while then driving again! Doesn't happen on first drive of the day. I disconnected the heater core and the problem still persisted. The flooring has been insulated completely, but the heat is coming thru the floor, side & center vents! AC helps a little, but air is still very warm. This happens tops on, tops off, windows up, windows down. I have been to 4 different corvette shops, (including a "leading" corvette dealer) no one can figure out the issue let alone fix it.
Old Jul 26, 2020 | 07:16 PM
interpon's Avatar
interpon
Is there a horsecollar foam seal between transmission and floor about even with firewall?
i didn’t even know one existed til i seen mine and repositioned it..still get small amount through e brake handle slot
Old Jul 26, 2020 | 07:27 PM
Aussie79vette's Avatar
Aussie79vette
I have the same problem with my 79, now I leave the hood popped open (close hood slowly and let rest on latches)
This lets the heat from the engine bay escape and not go into the cabin. My fellow club members pick me up
on not having the hood closed but NO heat.
Try it you will be surprised.
Andy
Old Jul 26, 2020 | 08:20 PM
BarryB72's Avatar
BarryB72
I saw a 63 convertible driving through the grocery store parking lot with his hood not latched just last week.
Old Jul 26, 2020 | 10:35 PM
Dodosmike's Avatar
Dodosmike
Andy
notice there is no “off” on your HVAC? Fan is always on low. Pull the plug on top
of the heater box. “L” shaped, pass side
install a heater core shut off or plug the pump outlet.
Old Jul 26, 2020 | 11:08 PM
Big2Bird's Avatar
Big2Bird
Is your fresh air intake stuck open?
Old Jul 26, 2020 | 11:24 PM
bubba998's Avatar
bubba998
4th Gear
The issue of the hot air is while driving. Doesn't matter if I let the engine cool down.
The heater core was completely by-passed and it did not solve the problem. I "believe" there is a problem under the dash. Leaking vacuum line, door that doesn't open/close????
Anymore ideas?
Old Jul 26, 2020 | 11:27 PM
bubba998's Avatar
bubba998
4th Gear
Sounds plausible. How can you tell if the fresh air intake is stuck open?
Old Jul 26, 2020 | 11:58 PM
Big2Bird's Avatar
Big2Bird
Take off the pass side kick panel and look.
Old Jul 27, 2020 | 01:20 AM
Bikespace's Avatar
Bikespace
I'm focusing on these clues:
Two ideas:
1. When you disconnected the heater core, did you drain the coolant? Is the core completely bypassed (short loop on the engine, or plugged)? If not, perhaps you are getting heat soak when sitting, and the then hot core is heating the air for a while. If the hot air persists for hours of driving, it's probably not that, but hot air may be entering the heater box through the missing insulation near the heater core inlet/outlet.
2. You said you brought it to four (4!) Corvette specialists. Did any of them adjust the timing to bring it back to factory specs? If so, your timing is almost certainly retarded from optimal, and your car is running hotter than it should. Can you shoot an IR temp gun at the upper radiator hose after running for a while, and let us know what it reads?
Old Jul 27, 2020 | 05:36 AM
Big2Bird's Avatar
Big2Bird
^^^This^^^^
Old Jul 27, 2020 | 01:51 PM
bubba998's Avatar
bubba998
4th Gear
When I disconnected the heater core it was leaking, so I doubt any coolant was left in it. Yes, I just put in a short loop back to the engine.
The engine does not seem to be running hot. It rarely gets above 200 degrees on the temp gage, even with the air conditioning on high. I will have the timing checked just in case.
The last "mechanic" broke the passenger side kick plate, so I am assuming he checked to see if the fresh air intake was stuck but I'll verify.
Old Jul 27, 2020 | 06:39 PM
Bikespace's Avatar
Bikespace
You may find that you are better at fixing your own car than the "experts", especially when armed with the proper tools (the GM Shop Manual, the Assembly Instruction Manual, and some diagnostic tools).
Please do check the fresh air intake, and confirm the temp gauge with an infrared temp gun. Your timing should be 36 degrees total mechanical advance at 2800-3000 rpm (no additional advance at higher RPM). But if you aren't checking this yourself, please let us know what the mechanic says. If he says something like "initial timing is 6 degrees BTDC, ported vacuum to the vac advance, just like the manual says", that'll be part of your problem, but easy to fix.
EDIT: You might want to read through this thread, too.
https://www.corvetteforum.com/forums...e-79-w-ac.html
Old Jul 28, 2020 | 11:43 AM
Sayfoo's Avatar
Sayfoo
Like said above, the door on the ac/heat duct is not closing.
Exactly the same problem I had on my '69.
To Cabin heat issue
