Master cylinder
Old Jul 30, 2020 | 07:23 AM
WHITE 1974's Avatar
WHITE 1974
Default Master cylinder
I have had to replace the master cylinder on my 1974 L48 automatic twice in the past 8 years. This last time I went through three different ones to get one that actually worked. And it failed after about 3 months driving. I have now ordered one from Summit and hope that's more successful. Anyone else have this issue? Could it be a bad booster maybe. I replaced that about 6 years ago. Thanks.
Old Jul 30, 2020 | 08:21 AM
HeadsU.P.'s Avatar
HeadsU.P.
The booster is strictly an assist, so you can lock up all four with a pinky toe.
However, if someone put the wrong booster on or the wrong booster rod, (too long) it could have damaged the MC.
First, stick with Delco MC instead of an aftermarket. Then you will know it fits properly and the critical gap between booster rod and the MC piston is spot on.
How are you bench bleeding these MCs? You might be damaging the piston seals if done improperly.
Click on my profile > photo album > bleeding, for some tips.
Old Jul 30, 2020 | 10:06 AM
Tampa Jerry's Avatar
Tampa Jerry
Consider having the M/C sleeved in stainless steel. I think Whites is still doing them. If after the sleeve is installed, and a rubber seal fails, a rebuild kit is very inexpensive and easy to install. Jerry
Old Jul 30, 2020 | 11:27 AM
Mrvettenick's Avatar
Mrvettenick
What was the mode of failure?
Old Jul 30, 2020 | 11:29 AM
WHITE 1974's Avatar
WHITE 1974
Appears to start leaking from the rear.
Old Jul 30, 2020 | 11:41 AM
Mrvettenick
That's a secondary cup failure. Were these new or rebuilt?
To Master cylinder
