Machine Shop Costs
Old Jul 30, 2020 | 12:47 PM
igilbert91's Avatar
igilbert91
Default Machine Shop Costs
Hey folks,
I am budgeting for a rebuild on the 79 L48, and am curious to hear what others are paying for machine shop work? I am based in the Bay Area of California, so I expect to pay a premium, but some preliminary quotes have been astounding.
I'd expect to do something like:
Clean and test block
Bore & hone .030
Replace cam bearings
Rebalance rotating assembly with new pistons
And depending on if I find some older vortec heads or buy something new:
Clean & test heads
Valve job
Also if you are in Northern California, I'll take any recommendations on shops
Thanks for any and all feedback
- Ian
Old Jul 30, 2020 | 01:41 PM
ddawson's Avatar
ddawson
I had Rob's Auto Machine in Hayward build my engine. Zero issues just took longer then expected.
Old Jul 30, 2020 | 02:11 PM
Jebbysan's Avatar
Jebbysan
Dr. Detroit
All of those items you had listed should be no more than about $800 on the high side.....$600 on the low side.
Jebby
Old Jul 30, 2020 | 02:19 PM
igilbert91's Avatar
igilbert91
Can I ask what that cost? Was it machine work + rebuild?
Old Jul 30, 2020 | 02:55 PM
Big Block Dave's Avatar
Big Block Dave
For a SBC don't even bother wasting money on a set of used heads. It doesn't take much to get in pretty deep that you are closing in on the cost of new aluminum.
Old Jul 30, 2020 | 03:15 PM
Duke94's Avatar
Duke94
Just had my 79' L48 at the machine shop (low mileage car). He honed cylinders, installed new freeze plugs and cam bearings and cleaned and inspected the rods and pistons polished the crank. Also magnaflux the block. Total cost was $480. He has bored out a few SBC for me in the past, and cost for that is about $170. I live in Michigan so probably cheaper than Cali. I agree with others, toss the heads and just buy a set of aftermarket aluminum ones.
Old Jul 30, 2020 | 04:19 PM
OldCarBum's Avatar
OldCarBum
Hi Ian,
Call LJ's Speed and Machine in Napa, CA. 707-255-4611 and talk with the owner, John.
They have been in business for over 50 years, building everything from blown alcohol monsters to John Deere tractors for the local farmers.
They are very respected in the community and well known.
They just put together my 496 and I couldn't be happier.
Greg
Old Jul 30, 2020 | 05:23 PM
stingr69's Avatar
stingr69
Bore, hone, deck, freeze plugs, cam bearings, acid dip is $500.
balancing is $200
valve job $250 plus any guides, parts or valves.
Old Jul 30, 2020 | 05:39 PM
cv67's Avatar
cv67
St. Jude Donor '05
Avg 800ish maybe more depending on what they do.
Assembling, balancing adds to it...prefer a good local shop over some crate place. Not that crates are bad but if you have an issue it leaves you in a bad spot...are they gonna honor it, shipping etc.
If you want vortecs you can buy brand new ones with screw in studs, all the good stuff. EQ may still make some, few others do also. My machinist retired which sux....reasonable did everything inc balancing himself. Hard to find places like that anymore
Mail order...vortecpro, Mike Lewis, tpi421vette here on the forum buiild incredibly durable/powerful mills. Quit doing it yrs ago no $ in it.
Old Jul 30, 2020 | 06:33 PM
Sigforty's Avatar
Sigforty
Cruise-In IX Veteran
It cost me about $600 just for the block work you described.
Old Jul 31, 2020 | 08:39 AM
stingr69's Avatar
stingr69
While we are on the subject.....a 383 stroker will cost the same. LOTS more torque below the peak (where you drive).
New crank is $250 so about the same as a regrind.
Special pistons are the same cost.
Rods should be replaced with 6" rather than reworked 5.7" so a wash cost wise.
Need to grind a bit for clearance here and there. No biggie.
Still need a balance.
This is EASY math here.
Old Jul 31, 2020 | 09:31 AM
71chimera's Avatar
71chimera
agree entirely on 383 route, but sometimes existing crank needs only a pro Polish by machine shop ~$20 and (instead of +10 or +20 bearing) some STDs / ONEs / TWOs bearing shells.
Old Jul 31, 2020 | 10:04 AM
joewill's Avatar
joewill
anything above a light hone means a fitting of new pistons.. which escalate the cost. so the boring and the new pistons ( all the way from cheap to very expensive) and the piston fitting to proper clearance are what drives the price way up.
clean/mag/top deck check,line bore check, cam bearings for the block, and clean mag, deck, valve job and seals for the head are the minimum you would get away with.
escalate that with pistons, valve seats, cam, springs, rods, crank, lifters, oil pump.. doubles the price
Old Aug 2, 2020 | 07:08 PM
ykf7b0's Avatar
ykf7b0
Originally Posted by igilbert91
Hey folks,
Bore & hone .030
Clean & test heads
Valve job
- Ian
A couple years ago I spent close to $900.00 for everything you mention above including head work with new valve seals, machining for springs on my vortec heads, and notching the block for a stroker rotating assembly. I'm in Tennessee.
Old Aug 2, 2020 | 09:46 PM
leigh1322's Avatar
leigh1322
Old Pro Solo Guy
I agree with the block work costs.
I spent: (Thru a friend)
  • Clean and test block - 150
  • Bore & hone .030 - 228
  • Replace cam bearings -80
  • Rebalance rotating assembly with new pistons -250
  • Clean & test heads
  • Valve job - 600 is std?
But you may run into other "suggested" work depending on condition.
How much machine work you want to do will depend on how far down the performance rabbit hole you want to go.
For instance do you need to or want to deck the block? or align bore the mains? Resize the rods? etc.
The heads on the other hand could easily go $600 alone for a standard valve job, more if valves or springs are needed.
My build costs in detail: (I went a little further...)
File Type: docx
Old Aug 2, 2020 | 10:47 PM
lars's Avatar
lars
Bore & hone .030
Clean & test heads
Valve job
Here are real prices:
Clean and test block: $120
Bore & hone with torque plates & replace cam brgs: $245
Balance rotating assembly: $190
Clean heads & Valve job (if no parts needed and no guides needed) $200
Total minimum for just the items you asked about: $755
But you have additional costs:
If crankshaft does not need to be ground, you still need to clean, straighten and polish it: $100
Re-sized & hone rods: $64
Press fit & align pistons: $104
Total base machining costs: Just over $1,000.
Plus parts, such as the pistons themselves, gaskets, bearings, cam, lifters, timing chain, oil pump, oil filter, oil, and any parts needed for the heads, such as valves and springs. Most likely, the heads will need guides, so just keep throwing money at it... I don't think you're getting away with anything less than $2,000 for a "basic" rebuild.
Lars
Old Aug 3, 2020 | 12:37 AM
OldCarBum's Avatar
OldCarBum
The basic machine work on my block was $1,240.00
Add in the cleaning, hot tank, mag check for cracks, bore and deck check to insure the block was even useable, $800.00
Plus the machine work to the new aluminum heads to swap the springs, clean up the castings in the runners, install the upgraded studs and surface $350.00.
You can do the minimum and get a long lasting rebuild.
But, as mentioned above, once you start down the performance rabbit hole you can easily get in to a stroker and drop $18,000.00 into it.
Decide your budget and stick to it, but leave room the all the little unexpected stuff like gaskets and seals, $200.00.
Old Aug 3, 2020 | 05:59 PM
jeffwebley's Avatar
jeffwebley
My LMS charged me about 1150 for clean/ check block, align bore, decked, .030 over bore, torque plate hone, clearance the block for the stroker crank, cam bearings, freeze plugs and bottom end ***'y.
He also re-balanced the stroker kit that I bought from summit.
I found a set of blueprint 195 heads for 500 on fleabay. They were on a Dyno mule. I checked the springs and put new valve seals in, and I super happy with them.
So, in flyover country, you can have a long block for about 2600.
I spent some more money on a retro roller cam from Erson, a set of retro lifters, full roller rockers, headers and a Weiand intake.
All told, somewhere around 5k. Including gaskets.
If you have the coin, go roller cam. Best decision I made on this build. Other than stroking it. Heh, heh,he said stroking it.
Good luck
Jeff
Old Aug 3, 2020 | 06:13 PM
jeffwebley's Avatar
jeffwebley
Oops
Jeff
To Machine Shop Costs
