Remote starter switch... just checking before I do something dumb
I have one of those remote starter button/switch gadgets which I have used on newer cars. one lead to a + and another to the S-terminal on the starter solenoid. On newer cars, the solenoid is often remote mounted in the engine compartment.
My '71 BB coupe has a standard starter (as far as I can tell)... appears to have a positive and an S-terminal like most starters I've seen. Before i blow something up... is there anything that is different on these cars that i should be aware of, before hooking it up and testing it? The last thing I need is an electrical short somewhere, but from everything I can tell, it is extremely straight-forward, just like other engines I've worked on.
It will sure beat cranking it by hand, if it all works!!
TIA.
Connect one lead to the top battery terminal and the other lead to the 'S' terminal.
Sucks, cause my valve covers are off and I'm ready to go!
Turn crank with socket on front bolt (trans in neutral).
1-8-4-3-6-5-7-2
90 degree increments. Lash each cylinder when it is at TDC. As long as cam is not too radical works well.
Easy. Takes me about 45 min from beginning to end. Usually do it when swapping plugs anyway.
1-8-4-3-6-5-7-2
I've got the valve covers off and these rockers seem too loose to me (glad I'm checking them). I'm thinking they are easily .025" cold lash. I believe they should be around .014 or so (alum head, iron block). Good news... visually, all looks good under there.
I tried the switch and it works. Enough work for today... I'll get to checking/setting the lash later in the week.Steve... any advice on setting cold lash? I have always worked with hyd roller valvetrain, which is extremely easy to set up. This is a solid roller lifter situation. As I said above, I'm thinking .014" cold. I checked a couple of the rockers at TDC and they are .016. I was wrong about .025" LOL But i know a couple have to be loose... the valvetrain seems a little louder recently at idle, which is why I wanted to check things out.
Am I correct in my thinking that once I feel some minor "drag" on the feeler gauge (at the chosen lash) from the roller tip to valve stem, that is proper and ready to lock into place?
One more thing to note, the Allen screw in a poly lock does not need to be crazy tight, if you’ve tightened and loosened the locks a bunch of times, it’s worth an inspection to see if the body has any hairline fractures. I consider them consumables, not lifetime engine parts. Seen it happen first hand, is the only reason I mention it.
As far as the cam goes... he chose a hyd roller grind, and installed solid roller lifters on it. Therefore, the cam card doesn't have lash for solid rollers. Again, I wouldn't have done that, but the engine runs really well. It makes nearly 400hp at the tires and over 440tq at the tires... so its a legitimate 475hp/530tq engine, which isn't bad at all for a mild BB that runs on 93 unleaded and is topped off with a low-rise intake that fits under the stock hood.
I decided to inspect the lash because I've owned the car for about 10 months now, and while it runs well, my ear tells me the valvetrain has gotten a little louder at idle. And I mean... just a little.
anyway, i found another solid roller cam by the same manufacturer (Herbert Cams) that is fairly close to the specs of this one, and they recommend .016-.018 lash. I have aluminum heads/iron block, so I'm thinking .012-.014 lash to make up for some expansion once everything is warmed up.
My question (because I'm not as accustomed to adjusting solid lifters) is when I check the lash (they are all at least .020 right now) and set it, should the feeler gauge be snug, or just a little drag on the roller tip/feeler gauge interface? I've seen the "Go/Don't Go" method, using two feeler gauges at .002" difference. Using this method, it seems like the feeler will be pretty tight on the "Go" lash setting.
I just don't want to screw it up, but I am confident that right now the lash is too much on just about all the valves.
there will be a drag on the feeler gauge, and you will have to be conscious that the feeler is entering the valve/roller parallel to the top of the valve. Otherwise easy to get a false “no go” when trying to put the feeler in. It’s hard to describe the amount of drag, but I’d say it’s more important to have the same feeling across the board as you set. +\- .001 won’t make a difference in your motor, but being able to monitor which ones changed and how much they changed (Hopefully no change!) at your next lash check is what I look for.
Next thing, is I ran a jumper from the neutral switch out under the hood so I can clip onto that and pickup power from the alternator output or the horn relay. The NSS or clutch switch, you want to use the 10ga Purple with the white stripe.. I put a two stud power strip doo-dad and hooked to that.
