Valve adjustment and finding 0 lash
Old Aug 7, 2020 | 11:45 PM
Jim71Vette's Avatar
Jim71Vette
Default Valve adjustment and finding 0 lash
Most of the "valve adjustment" procedures want you to twirl the pushrod until feeling a "slight" drag to signal 0 lash. I guess I'm a bad at "twirling" because I still end up with a noisy valve train.
I have read about moving the pushrod "up and down" until it stops and this signals 0 lash. This seems to work better but is it a better method?
Old Aug 8, 2020 | 12:37 AM
4-vettes's Avatar
4-vettes
Cruise-In VIII Veteran
What are we adjusting here Jim? Solids or hydraulic's? Hydraulic's are fairly forgiving. Have you tried adjusting the "Bubba" way? With valve cover off and engine idling , loosen rocker arm nut just till you hear it click. Slowly tighten till the click is gone, then half turn down. Then the next one and so on.
Old Aug 8, 2020 | 12:46 AM
Jim71Vette's Avatar
Jim71Vette
Sorry.... hydraulic. Adjusting while running is just too messy.
Old Aug 8, 2020 | 12:53 AM
4-vettes's Avatar
4-vettes
Believe it or not, it's really not that messy at idle. None the less, you need to learn to feel zero lash. Spinning works best for me.
Old Aug 8, 2020 | 10:39 AM
HeadsU.P.'s Avatar
HeadsU.P.
If you have stock style rockers, they sell clips to contain the oil spray. Come in sets of 8.
Then, using a strip of cardboard, install that between the springs and the valve cover ledge to divert oil.
No mess. Just don't rev it.
Old Aug 8, 2020 | 10:46 AM
Mrvettenick's Avatar
Mrvettenick
Are you adding the additional 3/4 turn after zero lash?
Old Aug 8, 2020 | 11:39 AM
7T1vette's Avatar
7T1vette
Use the "shake" method: With pushrod lightly held between thumb and fingers of one hand, continuously shake the pushrod up & down to feel the 'slop' in the system. With the other hand, slowly tighten the adjustment nut. You can EASILY find the point of 'zero lash' with this method.
Once you are skilled at the 'shake' method, your sense of feel becomes better for this process and the 'spin' method becomes easier to achieve. But, I still prefer the 'shake' method....it is almost fool-proof.
Old Aug 8, 2020 | 11:56 AM
stingr69's Avatar
stingr69
The "up and down" method is great for a first timer. If someone is asking how to adjust hydraulic lifters, that is a very good answer.
Once you have done that a few times, you can actually "feel" what a push rod feels like when the lifter is adjusted right. Spin it and feel the drag after you are done setting them. The drag is very slight due to all the hard oily steel in the assembly.
There is no good way to describe online the "feel" of it unless you already know. If it was easy, there would not be SOO many threads on it and SOO many different answers regarding the method and particularly the (exact??? really???) turns past zero. The number of turns past zero is in no way critical. You need enough turns to account for any potential future valve train wear and not soo much turns that you run out of adjustment travel inside the lifter. If you are too loose there is a gap and you can hear it. Too tight and the valve never seats so the engine runs bad. The lifters are not at all fussy about it so why are we all???
Old Aug 8, 2020 | 12:08 PM
cardo0's Avatar
cardo0
From: Las Vegas - Just stop perpetuating myths please.
Are you adjusting the lifters with the engine running? If not you need to follow the procedure to find zero lash on the lifter you are adjusting. If you can't provide us with correct information because you are trying to hide your error then we can't help you. Too many beginners are in denial they don't really understand what they are doing and setting lifter preload is very critical to protecting the camshaft and lifters from self-destruction.
Old Aug 8, 2020 | 12:13 PM
Mrvettenick
I agree with you, but it seems there are a few experts that disagree. I guess all the cam manufacturers are wrong too.
Old Aug 8, 2020 | 12:27 PM
ddsmith60's Avatar
ddsmith60
I find that it is very easy to feel with the up/down of the push rod. Moving the push rod up and down and slowly adjusting the rocker nut until no up/down motion is felt gets you there. Doing it this way doesn't matter whether the lifters have been filled with oil or not. You get to the zero lash position and give it 3/4 of a turn and you are done.
Old Aug 8, 2020 | 02:27 PM
Jim71Vette's Avatar
Jim71Vette
I'm not trying to hide anything. Im asking if the "shake" method is as good/better than the "twirl" method for finding 0 lash. I used Lars procedure to adjust the valves the first time while the engine was still on the stand. My only deviation was I didn't mark the damper at 90° intervals because the intake was off and I could easily see when each pistons valves where closed. Following the FO I twirled the pushrod while tightening the adjustment nut until I felt a slight drag(I thought) and then 1/2 turn for preload. I also used the Lars method to insert the distributor and set initial timing(8° BTDC). I put the engine on my run stand, and hit start. It started and ran for 30 minutes at 2200 to 2500 rpm. The valve train just seemed noisy to me.
a
Old Aug 8, 2020 | 06:02 PM
pltmgr's Avatar
pltmgr
Strictly an amateur here. Recently adjusted the valves on my BB 71 with engine running. Did not use any clips and the cardboard I placed at the bottom of the heads had no oil on them when I was done. I made sure the engine was warm enough before starting so the idle was as low as possible.
Old Aug 8, 2020 | 07:04 PM
cardo0's Avatar
cardo0
a
Without being there I can't say you did anything wrong. But the results don't sound good. Something else that I don't like to hear is using less than 1 full turn pre-load. I don't care how many or who says to use less you won't find any shop manuals saying use less than one full turn. The excuse given is if you run the engine to high enough RPM to make the valve float it will pump up the lifters and hold the valves open. Well you should never run the engine past redline regardless so it shouldn't be an issue unless you frequently abuse your engine past the cam redline enough to break it.
So I don't know what your looking for if you say you adjusted the lifters correctly on base circle and at zero lash. Lifters make noise when their loose (not tight) so either there's not enough pre-load or the lobes are wiped already. Sorry to be so pessimistic but from my own experience I know a cam lobe will wipe in a few minutes - before the 20 min break-in is done. It will be unbelievable and hard to admit to yourself if it happens but a lesson not forgotten. Once you pull out the noisy lifter and see for yourself you can't deny it.
Old Aug 8, 2020 | 08:27 PM
Roy W.'s Avatar
Roy W.
Disabled by request 8 JUN 2025
Default Another Method
Another way that has been referred to here before (I think it was Rescue Rogers) is to throw away the lock nuts and use poly locks. With the set screw in the poly lock backed out some, slowly turn the poly lock down between your fingers until you encounter some résistance. That is zero lash. From there turn down the required number of turns (your choice) and then while holding the poly lock with a wrench, tighten the set screw. I find that locating zero lash using is procedure is easier than the "twirling" method. NOTE: if using stock valve covers make sure the valve cover clears the poly lock.
Old Aug 8, 2020 | 09:39 PM
Big2Bird's Avatar
Big2Bird
One full turn gets the plunger centered, and GM did that for warranty and durability.
If you do a 1/2 turn preload, you gain a tad of of HP.
If you live long enough to trash a lifter that way, happy days.
Old Aug 8, 2020 | 09:51 PM
7T1vette's Avatar
7T1vette
I don't believe there is any advantage to setting hydraulic valves on a running engine. Nothing against doing that...but, to me, it's just unnecessary. For solid lifters, gotta be running, for me.
I agree with the above post about the 'amount' of pre-loading needed for hydraulic lifters (on Chevy engines). GM wanted 1 turn...just like they wanted to set ignition timing at 8* BTDC (or even more retarded than that!). For the average enthusiast, 3/4 turn (CW) after zero lash seems about right to me. If you are trying to get more revs out of the engine before the valves float, 1/2 turn is better, IMO.
To Valve adjustment and finding 0 lash
Old Aug 8, 2020 | 11:20 PM
cardo0's Avatar
cardo0
Your spreading disinformation. No, no, no, less preload preload reduces lift and makes less power. That's a fact Jack. The greater the preload the less the little piston inside the lifter can travel when compressed by the cam lobe and valve spring and the less lift is lost by the lifter. The greater the preload the higher the valve lift and the more power tge engine will make. The less lifter preload used the more that little piston inside the lifter can travel/compress and the greater the lift is lost.
It's assuming posters that don't know how a lifter works or what preload does that perpetuate stupid assumptions. Get pictorial of a hydraulic lifter and figure it out for yourself. And please stop posting bad information.
Old Aug 8, 2020 | 11:51 PM
ronarndt's Avatar
ronarndt
I thought I would check out the Corvette Forum to get away from all of the arguments on facebook between competing political parties. I think I will go back to fb to get away from the valve lash fanatics!
Old Aug 10, 2020 | 11:33 AM
Jebbysan's Avatar
Jebbysan
Dr. Detroit
It was me and this is the way I do it. 100% the most effective way......BUT the studs must be in good condition and free of galling.
Spin it tighter with your fingers and when zero lash happens......you can feel the spring in the bottom of the lifter start to plunge.......roll it back and forth from this spot to verify, from there....do your half turn and lock. Perfect everytime.
FYI.....I also use the TDC through the firing order method....each cylinder is at TDC...adjust both valves at that cylinder.
Jebby
