new crate/trans combo?
Old Aug 16, 2020 | 10:06 PM
onaqwst's Avatar
onaqwst
Default new crate/trans combo?
Took the vette out a few times this year and still dealing with some engine(timing/no go)/trans(leaks/hard shifts-auto) issues. Been thinking about doing a full crate engine/trans swap just to avoid chasing down issues in the future. I have to get the main seal/gaskets in the trans done due to leaks, so figured it might be best to swap everything out for new/rebuilt since they might have to drop the trans anyways.
Old Aug 17, 2020 | 03:17 AM
mrichi's Avatar
mrichi
Put in a big block with a t5 tremec behind it you will love it
Old Aug 17, 2020 | 03:42 AM
Bikespace's Avatar
Bikespace
Timing issues should be easy, or at least cheap, to fix. Adding a third pedal will solve your transmission problems, and make the car so much quicker, you may not notice the engine.
Old Aug 17, 2020 | 09:49 AM
cv67's Avatar
cv67
St. Jude Donor '05
Crate 400 will pull a 3.08 gear fine, no need for OD or regearing. Those engines make tons of torque
All you need is a half decent head, headers and roller cam;tough to beat for the $
Old Aug 17, 2020 | 11:34 AM
scottjamison's Avatar
scottjamison
Go to BlueprintEngines.com for your engine.
Go to Silver Sport Transmissions for the Tremec TKO600. https://shiftsst.com/
You won't be sorry.
To new crate/trans combo?
