Need Help!!! (electric fan wiring)
bought Flexalite fans from Ecklers. By the way, Flexalite have been great.
Painless harness. ..... well that many breakdowns later. Let me tell you to pitch this in the garbage RIGHT NOW!!!. save yourself the breakdowns!
to run your fans. You need a thermo switch or a fan controller or run them off your EFI.
I am happy to help you, first, how are you switching the fan or fans? Thermo switch? Or ECU.
second, one or twin fans?
Pull power for the fans at the solenoid, positive battery cable connection. Top large post.
there are only 4 wires to a relay. One to ground which is the thermo switch. One to switched power. This is a very light load so acc. Power at fuse panel is a good spot. One to the fans and of course main power taken off the solenoid.
All the wiring in the painless kit is undersized.
The circuit breaker is a BAD idea. Replaced 3 of them.
I can get far more specific if I know more .
Use a fuse down at the solenoid connection. I'm running a 60 amp fuse and 60 amp relay with twin fans.
Scrap the painless kit right now!
get back to me with what your running and I think I can save you the pain I went through with the "painless " fan harness.
For the main 12v power for my elec fan as well as “switched” power I pulled both from the always hot main lug on the alternator. If I happen to shut down when the fan is spinning it will continue to cool until the thermoswitch is satisfied regardless of ignition switch position.
I feel like it can’t hurt for the spal fan to be blowing air all over the engine components as things cool down. The most it’s ever run in this situation is about 5 minutes. Obviously you need a healthy battery/charging system for this to reliably work.
One time I shut the engine down when it was right on the cusp of getting hot enough to turn the fan on. It came on about 1 minute after I had switched off as heat soak made the thermoswitch go to ground. She ran a couple minutes and switched off.
Of course the thermoswitch might fail someday when you’re away from your car and your fan would run continuously until your battery was dead. On my C3 I have a simple knife blade switch on the negative battery terminal that I use anytime I’m away from the car for any meaningful length of time.
This setup is not for everyone but it works for me.
You can get your ignition source off the fusebox-
As far as acc & ignition-
The acc wire is hot in ACC and ignition -but not start ( yellow- used for wipers and radio)
The ignition wire is not hot ACC but hot ign and start (pink- gauges/turn signals
You don't want to wire the fans to the alternator- it can't handle the start up surge for the fan(s)- especially since usually the car is at idle and the alternator is NOT able to produce full power-most (dependent on pulley size) are full output 1500-1800 RPM.
Wire as close to battery as possible- Starter lug works great- as the battery will stabilize the voltage and have more current available when needed.
Think of the alternator as income and the battery as your bank account...at idle the alternator is only earning part time money!!!
Another issue that might arise- if you have a stock alternator- you might run into problems keeping up with the power demands- and ending up with a dead battery.
You might want to look at something like this- a PWM- Pulse Width Modulation controller for your fan(s)
1) Uses a soft start- doesn't pull full current immediately when the fan(s) start up
2) Has it's own temp sensor - and uses temperature to control the speed of the fan(s)- so only runs them full speed when needed
3) Has built in relay to control the high current switching
4) Has an over ride switch to turn on the fan if ever needed
5)No need to run an ignition wire-
PWM-
https://www.summitracing.com/parts/der-16796
PWM-
Where exactly on the fuse box do I get the ignition source? do i need to run a wire into the cab of the car? Or is there a way to hook in from the engine harness.
ouch. Thanks for the heads up!
The sensor they provide that is on at 185* and off at 175* is too low a temperature for a 180* thermostat. It will basically keep the fans on all the time unless you're running a 160* thermostat.
From looking at the picture, I'm tending to believe the wiring is too small a gauge for dual fans too.
Thermo switch,
twin fans
second, the only thing in that painless kit that is usable, is the thermo switch. As someone else pointed out. Will pretty much have your fans running all the time once you've reached warm up.
this isn't the worst thing. But if your cooling system is set up properly, you really shouldn't need to be running them on the hiway.
if you haven't ordered this kit yet, don't. Look on Summit for just the thermo switch. They are available in different temp settings
with twin fans, you can wire with 2 fuses and 2 30 amp relays. Or one larger fuse and a large heavy duty 60 amp relay.
for Alternator , electric fans, headlight relays, etc. I would suggest you look up "Mad Electrical ". There web page is full of information as well as they can help you with parts.
have had 3 circuit breakers fail. Circuit breakers just don't work with underhood temps and fan startup surges. Use a fuse. The relay they supply is not enough for twin fans. Melted the connections twice and changed 4 relays. Melted wiring connections at the fans.
the painless kit is just not up to twin fans.
you need a proper fuse, not a breaker. You need heavier wire. And you definitely need a properly setup charging system.
if you haven't gone to Mad Electrical's web site and read there tech pages on Alternators yet. Please do so.
My 75 has been configured this way for 2 1/2 years and 5000 miles with zero issues. As pointed out by others any fan activity is nearly always at idle. My fan kicks on strong whenever necessary regardless of engine rpm.
Granted my car does have a modern alternator and otherwise healthy electrical system.
The wire off the alternator was NEVER designed to handle that kind of current- You do realize if the alternator doesn't supply the power for the fans- the current will be pulled from the battery.
The wire runs from the starter THROUGH a fusible link- which could easily be burned by pulling too much current- its a 10GA wire that's already maxed out by the factory electrical- GM cut corners here...
I just don't recommend it...
