350 no fire on 4 cylinders.
Old Aug 17, 2020 | 06:21 PM
formor2go's Avatar
formor2go
3rd Gear
Default 350 no fire on 4 cylinders.
when my 72 runs like **** I can pull every other plug wire off the cap and notice no difference in running but when i put the wire back on I can hear the spark jump.Have a msd6a on it. Any suggestions? 350
Old Aug 17, 2020 | 06:29 PM
CAMS69's Avatar
CAMS69
Default Guess
if I have to guess, firing order in plugs is wrong
Old Aug 17, 2020 | 06:45 PM
71chimera's Avatar
71chimera
ya don't have to remove the box yet, but take the box out of the loop and run ignition as OE.
Old Aug 17, 2020 | 06:48 PM
formor2go's Avatar
formor2go
3rd Gear
Order is ok, will take the box out tomorrow and see. You think that's the probable cause?
Old Aug 17, 2020 | 06:49 PM
formor2go's Avatar
formor2go
3rd Gear
Seems to happen when its hot and run for a while.
Old Aug 17, 2020 | 06:56 PM
71chimera's Avatar
71chimera
JMO if not probable, certainly plausible. They do puke
If ya truly NEED a CD box on a street car, likely carb & rest of ignition could use some help first. JMO YMMV
Old Aug 17, 2020 | 07:50 PM
MelWff's Avatar
MelWff
Did you remove the cap and check the contacts and the rotor?
Old Aug 17, 2020 | 08:02 PM
7t9l82's Avatar
7t9l82
Check wires and connection too.
Old Aug 17, 2020 | 09:04 PM
Jebbysan's Avatar
Jebbysan
Dr. Detroit
If it is an old 6AL......look on the side and see of the cylinder disconnect wires are corroded or cut......these are clipped when running a 4 or 6 cylinder......these are on the soft touch disc on the side of the unit.....
Jebby
Old Aug 17, 2020 | 10:21 PM
SJW's Avatar
SJW
Sounds like a clogged jet or passage in the carburetor. Each plenum of a dual-plane manifold feeds alternate cylinders.
Live well,
SJW
Old Aug 19, 2020 | 02:36 PM
7T1vette's Avatar
7T1vette
If the 4 non-firing cylinders are all on one side of the engine, problem is with the carb or the intake manifold / gasket. Otherwise, distributor cap is the likely culprit.
(Assumed that you were already checking out the spark box...)
Old Aug 19, 2020 | 07:47 PM
HeadsU.P.'s Avatar
HeadsU.P.
On a std dual plane, SBC Intake Manifold:
Drivers side carb butterflies & Intake ports feed cylinders; 1-4-6-7
On the passengers side of carb, they are fed to cyl; 2-3-5-8
Old Aug 19, 2020 | 10:10 PM
SJW's Avatar
SJW
Yup. This engine either has a fuel-delivery problem on one primary venturi, or a large vacuum leak that's only leaning out one plenum of the dual-plane intake manifold. It's almost certainly something clogged in the carburetor. A rebuild of the carb should solve the problem.
Live well,
SJW
Old Aug 19, 2020 | 10:19 PM
Sigforty's Avatar
Sigforty
Cruise-In IX Veteran
is the box set to run the correct amount of cylinders?
Old Aug 20, 2020 | 09:34 AM
71chimera's Avatar
71chimera
IIRC
6AL has cylinder select loops
IIRC
6A does not
-add-
regardless, 6 box may've puked
Old Aug 20, 2020 | 03:34 PM
HeadsU.P.'s Avatar
HeadsU.P.
Live well,
SJW
Only if those four cylinders mentioned coincide with your four cylinders issue.
Old Aug 20, 2020 | 09:09 PM
SJW's Avatar
SJW
OP said:
"I can pull every other plug wire off the cap and notice no difference in running but when i put the wire back on I can hear the spark jump."
So it's missing on every other cylinder and he's getting spark to the dead cylinders.
It's either running on 1, 4, 6 & 7 and missing on 8, 3, 5 & 2, or it's running on 8, 3, 5 & 2 and missing on 1, 4, 6 & 7. He hasn't told us which four are missing, but that'll be the clue to which side of the carburetor or intake will have the fault. My bet's on a clogged jet or passage in the carb.
Live well,
SJW
To 350 no fire on 4 cylinders.
Old Aug 20, 2020 | 09:47 PM
bruiser's Avatar
bruiser
St. Jude Donor '15
Mine just did the same thing, Was bad sparkplug wires
Old Aug 20, 2020 | 10:46 PM
forman's Avatar
forman
MSD al6 boxes like to run with a full 12 volt from a dedicated line from the battery if the battery is low or theres corrosion it will mess with the box ,, make sure everything is tight
Old Aug 21, 2020 | 12:16 AM
7T1vette's Avatar
7T1vette
Also can't be fed (properly) with the factory 'resistance' wire.
