1968 Speedo
Old Aug 19, 2020 | 10:15 AM
Dale68's Avatar
Dale68
Cruising
Default 1968 Speedo
Hi, I recently had my drivers side instrument panel out , i did everything i needed to do , reinstalled it and everything was working correctly except i noticed the speedo wasn't working after i took it out . i figured ok thats an easy fix , just loosen everything back up and and reinstall the cable , which i am trying to do now but its like i can't get it to fit , is there a trick ?, i can get the end of the cable into the back of the speedo but i can't screw the attachment onto the back of the speedo , its like it wont reach , or wont go in ?
what am i doing wrong ?
Dale
Old Aug 19, 2020 | 11:29 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
My guess is the speedo drive cable is not fully seated in the speedo head.
Old Aug 19, 2020 | 12:31 PM
Dale68's Avatar
Dale68
Cruising
Thanks for the reply, i think you are right , however i am an idiot and got frustrated and took my wire cutters and snipped the end of the cable that goes into the speedo off a little bit to try and make it so i could screw it in , it didn't work , so i played with it a bit more and finally the cable seated properly , so then i screwed it into the speedo and it still doesnt work , so i am thinking that i screwed the cable up when i cut a little bit off the end , do you think that would be the case ?
I ordered a new cable
Now my Tach doesnt work , worked fine this morning , its screwed in and wasn't touched , maybe i pulled it out a bit when i pulled the dash out a bit ... man these cars are so hard and frustrating to work on.
Old Aug 19, 2020 | 12:35 PM
Rescue Rogers's Avatar
Rescue Rogers
Is my vette stock?? HAHA
2016 C3 of Year Finalist
If the cable is sticking out of the sheath try disconnecting the other end at the trannny, maybe the cable isn’t in the the tranny fully. If you can, try and spin the cable with your fingers and push it back into the sheath.
Old Aug 19, 2020 | 02:05 PM
7T1vette's Avatar
7T1vette
You need to buy a new cable. Shortening it was NOT the thing to do. Removing the other end from the trans and turning the cable while trying to insert/seat the cable into the speedo socket is how you get that done correctly. Are you fully depressing the locking clip BEFORE (and while) you insert the cable in the speedo? You should only release that clip once the cable has fully seated into the socket.
Old Aug 19, 2020 | 02:09 PM
Rescue Rogers
again no. The 68 cable has a threaded cap on both ends. Do not buy a new one. Hopefully you didn’t cut it too short. If it worked before then it would still work. Cutting it was a bad idea unfortunately
Old Aug 20, 2020 | 07:54 PM
Dale68's Avatar
Dale68
Cruising
I did buy a new one , just waiting for it to arrive , I think i cut it too short , just frustrated , oh well hopefully the new one will work , I got the tach to work , all the lights work , everything is good , just the speedo , so will report back once i get it .. and yes the 68 has a threaded cap on both ends , i shouldn't have cut it , stupid move.. i just couldn't get it to seat correctly , Now I know ..LOL
Old Aug 20, 2020 | 07:57 PM
Rescue Rogers
Good luck, let us know how it goes
Old Aug 21, 2020 | 12:25 AM
7T1vette's Avatar
7T1vette
All GM speedo cables of that vintage have screw-on end pieces...on the SHEATH. The man cut the CABLE too short....
Old Aug 26, 2020 | 06:26 PM
Dale68's Avatar
Dale68
Cruising
Cable finally came in and ten minutes later we have a working speedo... awesome ..Thanks
I also took the opportunity to replace the drivers side door jam light switch , however i noticed that if i connect the two wires to it and screw it in all the way , my indicators ( right and left ) don't work and the courtesy light stays on even when the door is shut , if i unscrew it a bit the indicators work and the light shuts off when the door is closed , what is that all about ?
Ground ??
Thanks again
Dale
Old Aug 26, 2020 | 07:37 PM
Rescue Rogers
You are correct, the switch may not have had a good ground. THe switch itself just connects the white wires to ground so the without the ground the electricity found it ground through the dash lights.
Old Aug 27, 2020 | 11:05 AM
Dale68's Avatar
Dale68
Cruising
Thanks , Thats what I thought .. I'll check the ground
appreciate the help
Regards
To 1968 Speedo
