Measuring engine rpm?
Aug 19, 2020 | 04:11 PM
What is the best way to measure engine rpm without a tachometer? Don’t want to spend a lot on a device I will not use very often.
Aug 19, 2020 | 04:21 PM
I assume you mean without a working in car tachometer?
Look at Harbor Freight automotive multimeter includes tach
Aug 19, 2020 | 05:08 PM
My dial back timing light shows RPM.
Aug 19, 2020 | 05:19 PM
I found a multimeter at harbor freight that measures rpm.
Aug 19, 2020 | 05:50 PM
Aug 19, 2020 | 06:32 PM
Quote:
Originally Posted by
Domobomb
I thought about that but already have an advance timing light. I’ll probably return the multimeter after I use it.
Aug 19, 2020 | 09:06 PM
Bhebert449
So you're one of those cheap bastards that return a tv after watching the super bowl?
Aug 19, 2020 | 09:14 PM
Royal Canadian Navy
Aug 19, 2020 | 09:23 PM
bashcraft
lol. I only need to use it once.
Aug 19, 2020 | 09:30 PM
Get an Inova and trash the rest. (Or return them).
Aug 19, 2020 | 09:31 PM
Cheap
I guess as long as you don’t return the toilet after you’re done, I am okay with your plan!!
Aug 20, 2020 | 01:12 AM
Big2Bird
Exactly!
Innova 5568 . It works well to check RPM, and you can even use it to set your timing.
What kind of person returns tools? That's crazy-talk!
Aug 20, 2020 | 12:05 PM
Cruise-In II Veteran
Bhebert449
...I only need to use it once...
Use it, then put it up for sale in Parts for Sale.
Aug 20, 2020 | 01:28 PM
BORROW ONE !!! If you don't know anyone with a portable tachometer, call Auto Zone, Advance, or O-Reilly's and ask if they have one you can use or rent for a day.
Aug 20, 2020 | 01:59 PM
Aug 21, 2020 | 12:29 AM
Hey! I think I saw one of those on Antiques Road Show. It got appraised at $5000. No,...wait...that was $5.
P.S. If it still works, it's a "keeper"!
Aug 21, 2020 | 11:43 AM
If you were closer, I have close to 20 dwell tachs.
I also have the Sun tool to calibrate them.
