700R4 Transmission
Old Aug 23, 2020 | 03:56 PM
PRIrish's Avatar
PRIrish
Default 700R4 Transmission
If you have a 700R4 transmission in a 1976, does the original dip stick measure the oil level correctly?
Old Aug 23, 2020 | 04:13 PM
MelWff's Avatar
MelWff
The original dipstick and tube according to posts on this forum do not fit a 700R4.
Read this link, a search will come up with more
https://www.corvetteforum.com/forums...in-a-77-a.html
Old Aug 23, 2020 | 07:46 PM
PRIrish's Avatar
PRIrish
MeIWff, thanks for the information and the link. My problem is whether the transmission is overfilled or not. The car had a ZZ4 crate engine and 700R4 when I purchased it in 2010. I had the transmission fluid and filter changed in July, 2019 since it had around 30 thousand miles on it. There were no metal material in the pan, and they added 5 qts of fluid. A few weeks back I noticed two small pools of fluid on the floor. I took it to a friend who has a lift, and it seemed to be leaking at the rear seal. However, I've taken it on three 100 mile rod runs since then, and it has not leaked anymore. Wondering if the fluid might be low considering the one time leak, I checked the fluid today after a 120 miles rod run, and it shows to be overfilled. I don't know if it has the original dip stick, and if so, causing it to show overfilled, but it doesn't stick up pass the top of the air breather....I say this as it was referenced in the link that the original dip stick stuck up too high. Any further suggestions/comments?
Old Aug 23, 2020 | 08:53 PM
MelWff's Avatar
MelWff
You checked the fluid while the engine was running and after manually shifting into each gear and then back to park?
Old Aug 23, 2020 | 11:52 PM
7T1vette's Avatar
7T1vette
If by 'original dipstick' you mean the stick that came with the THM-350 that was built into the car, NO. But, if you mean that the 700-R4 transmission in your car has the same dipstick and tube that IT was built with, you will be fine. You cannot swap dipsticks and/or tubes with different models of transmissions or engines and expect them to read correctly. Could they read correctly? Maybe......
Old Aug 24, 2020 | 09:45 AM
PRIrish's Avatar
PRIrish
No, I did not go through the gears. I will try that to see if it makes a difference.
Old Aug 24, 2020 | 09:57 AM
PRIrish's Avatar
PRIrish
7T1vette, I did not know a 700R4 came with the dip stick. If that is the case, I will assume it has the one that came with it. I will warm it up and go through the gears as MelWff suggested. If the dip stick still shows it to be overfilled, I plan to take it to the shop that changed the fluid and filter and have them drain out some fluid, and hope the rear seal has been damaged.
Old Aug 24, 2020 | 09:59 AM
PRIrish's Avatar
PRIrish
7T1vette, I meant to say I hope the rear seal has NOT been damaged.
Old Aug 24, 2020 | 11:13 AM
71chimera's Avatar
71chimera
If in doubt whether DS is correct; go to local junkyard and get an OE stick AND tube from a vehicle with an OE 700r4.
most tubes are SEALED to trans housing with a pressed-in rubber O-Ring. Don't let any dirt into that union Nor allow any water into it. DO maintain integrity of that seal.
ANY water in auto trans WILL Destroy it Very Quickly.
Old Aug 24, 2020 | 01:01 PM
PRIrish's Avatar
PRIrish
MelWff, I did as you suggested and after warming up the fluid, I shifted through all the gears before placing it in park and checking the fluid level. It made a difference in that when I checked it the first time it showed about 1/2 inch about the full mark, and now after going through the gears it show about 1/8 to 1/4 above the full mark. I don't know if this is significant or not, but I will go ahead and take it back to the shop that did the fluid replacement and have some fluid pumped out to be on the safe side.
I want to thank everyone for their suggestions/comments. This is not the first time members of Corvette Forum have assisted me with my 76 Vette problems.
Old Aug 24, 2020 | 01:45 PM
7T1vette's Avatar
7T1vette
If the dipstick in the 700R4 came with a 700R4 unit, then your dipstick will read correctly. Otherwise, you are just guessing.....and that's not a good thing to do with an automatic transmission. It is important to have the correct amount of oil in the transmission system.
To 700R4 Transmission
