1977 factory wheels
Old Aug 27, 2020 | 11:44 PM
Jcwiii's Avatar
Jcwiii
6th Gear
Default 1977 factory wheels
Hello new to group
3 weeks ago I got a 77 corvette with factory steel wheels 1976 date code having a problem with wheel rub on front at the frame and sway bar when you turn hard what can I do? The tires are 225/70 r 15 thank you for the help
James
Old Aug 27, 2020 | 11:53 PM
bruiser's Avatar
bruiser
St. Jude Donor '15
Make sure you have these steering stops on and on the correct side
Old Aug 28, 2020 | 12:00 AM
Jcwiii's Avatar
Jcwiii
6th Gear
Default Wheels
Originally Posted by bruiser
t
thank you will check out tomarrow after this just a few more bugs to weed out
Picture of wheels
Old Aug 28, 2020 | 04:35 AM
4-vettes's Avatar
4-vettes
Cruise-In VIII Veteran
I'm running 255/60 -15's. Have been for over 30 years. Factory alloy slots on my 77. No issues
Old Aug 28, 2020 | 06:27 AM
Shovels and Vettes's Avatar
Shovels and Vettes
I also ran 255/60R15 tires on my 77 without any rubbing issues.
Old Aug 28, 2020 | 10:31 AM
Jcwiii's Avatar
Jcwiii
6th Gear
hello again I only see two bolts that hold in the lower ball joint. It toward the bottom of your picture. Don't get me wrong but is the stop on the left side of you picture that metal tab sticking out ? Think mine are shot what can be done? Weld a new tab or tap and thread a new stop bumper? I am new to corvettes but have worked on my cars for 30 years and never ran in to this problem
Passenger side
Passenger side frame
Passenger side
Drivers side
Old Aug 28, 2020 | 11:00 AM
bruiser's Avatar
bruiser
St. Jude Donor '15
The stops are part of the bolts that hold the ball joint on. Yours are missing or on the other side.
Old Aug 28, 2020 | 11:05 AM
Jcwiii's Avatar
Jcwiii
6th Gear
There are just bolts I will have to look in to it more thank you
James
Old Aug 28, 2020 | 12:07 PM
bmotojoe's Avatar
bmotojoe
The special attaching bolt should be on the side facing front of car of each control arm.
The correct ball joint and hardware kit from MOOG is K-6035.
Example:
Amazon Amazon
Old Aug 28, 2020 | 12:19 PM
Jcwiii's Avatar
Jcwiii
6th Gear
Example: https://www.amazon.com/Moog-K6035-Ba.../dp/B000C57XPI
ya it looks like front end work was done a lot of bubba In the car. They might have wanted more angle for the wheel so they removed. Will have to see what I can do. What is the tab on the back because I found other post on this forum that said that the tabs were the stops they look like they are warn out. Thank you for your help
Old Aug 28, 2020 | 12:29 PM
bmotojoe's Avatar
bmotojoe
I just went out and looked at my 77. The upper & lower ball joints are still original and riveted.
These joints were riveted originally to speed up installation on the assembly line and not bolted.
I don't see how NOT having that special bolt makes much difference in your case. I wouldn't focus only in that area .
Old Aug 28, 2020 | 12:54 PM
bmotojoe's Avatar
bmotojoe
So to give you some idea how long that welded stop tab should be.
The area under the point has a radius cut in it, most likely for tie-rod sleeve clearance.
Hope this helps.
Old Aug 28, 2020 | 02:13 PM
Jcwiii's Avatar
Jcwiii
6th Gear
Hope this helps.
that helps mine is only 3/4 inch total the spindle also hit lower control arm so yes I would think it was shot. Someone did some grinding
To 1977 factory wheels
