Another 1978 Pace Car Antenna Problem
Old Aug 28, 2020 | 07:58 PM
78/500's Avatar
78/500
4th Gear
Default Another 1978 Pace Car Antenna Problem
Friends,
I'm new, but it only took about 5 minutes to learn that finding a power antenna replacement for a 1978 Pace Car is quite a challenge. I'm not sure if i should say "fortunately" or "unfortunately," but my '78 has an AM/FM/CB radio, so finding a power antenna w/ CB feels like trying to find Jimmy Hoffa's gravesight.
For me, the issue is that the mast broke near the top. The motor still works, and I have the remaining mast sections which do go up and down (albeit not completely, as the new "top" is bent a bit), as well as the cap. If anyone has any advice on where or how to find a replacement, or if this can be repaired, I would be most grateful!
Another member suggested I repeat this post and question here -- thanks in advance for any help or advice you can lend!!
Thanks very much!
Gino P
Old Aug 28, 2020 | 08:12 PM
Richard454's Avatar
Richard454
Jimmy Hoffa's under the pitcher's mount at the Giants Stadium!!!
Try these guys-
https://theantennasource.com/CHEVROL...1979-1982.html
Old Aug 29, 2020 | 12:03 AM
Shark Racer's Avatar
Shark Racer
I sourced parts from Antenna Masts R Us when the cable broke in my original antenna: It worked out well. https://www.theantennasource.com/CHE...te%201978.html
Old Aug 30, 2020 | 08:02 PM
Corpor's Avatar
Corpor
I am looking for alternatives also, but I just found this part.
https://www.zip-corvette.com/79-82-p...ly-w-o-cb.html
Old Aug 30, 2020 | 08:18 PM
interpon's Avatar
interpon
I think 78 also unique..my early 79 has a 78 antenna and it was aluminum I think..and different.
not sure whats different on cb or not though..
suggest rebuilding it
https://www.corvetteforum.com/forums...na-wiring.html
Old Aug 30, 2020 | 11:40 PM
Corpor's Avatar
Corpor
Not the re-builder type! Rather replace.
Old Aug 30, 2020 | 11:54 PM
Shark Racer
Maybe the market’s changed since I had to do mine a few years ago, but my Pace Car’s antenna was impossible to find a service replacement for, I would have replaced instead of rebuild as well. Mine is not a CB antenna, CB antennas are even more rare. Mine was a fairly straightforward rebuild, but I’m sure if you call around you’ll be able to find someone you can send the unit to for an overhaul.
Old Aug 31, 2020 | 12:01 AM
Corpor's Avatar
Corpor
Just found my answer! Hidden antenna, plugs in, no drilling, yadi, yada.
https://www.ecklers.com/1953-2015-co...-342505-1.html
Old Aug 31, 2020 | 11:52 AM
Shark Racer
Cool. I'm sure you know this, but that won't work for CB, so you won't be able to run blocker for any big rigs...
Old Aug 31, 2020 | 02:44 PM
78/500's Avatar
78/500
4th Gear
You guys are all awesome -- Thank you. I genuinely appreciate the help.
I reached out to The Antenna Source to see if they can repair/rebuild the broken mast on my antenna. Fingers crossed... (or I may end up getting a non-CB replacement... for now).
Funny thing about Ecklers -- I grew up in Titusville, FL and went to school with one of the Eckler boys. The company was just starting out then...
Thanks again,
Gino
Old Oct 16, 2021 | 05:50 PM
Caddy Jack's Avatar
Caddy Jack
2nd Gear
Default 1978 Corvette CB Power Antenna
The 1978 corvette antenna with cb option is a one year only and no other GM antenna is configured that way I have a refurbished one for sale the cost is $ 1500.00 I also know some one with a nos one but it should be refurbished due to it’s age it would probably only go up and down 20 times and then snap the drive cable
Old Oct 17, 2021 | 03:53 AM
hunt4cleanair's Avatar
hunt4cleanair
Why not post this in the For Sale forum where it belongs? Members can joke about the price over there!
To Another 1978 Pace Car Antenna Problem
