Questions for Enthusiasts
If I was you I would get yourself a corvette black book. Lots of info on each year. :seeya
Find the body style that you like and buy the BEST one you can afford. The Forum Archives is a great tool - access that with the "search" link under Forums on the left side of the screen.
Monitor this forum for a while, common problems will show up. Rust is a problem with some cars and is $$ to repair. Common rust points are the frame ahead of the trailing arms, the windshield frame, and the radiator mounting bracket. The good news is these cars are very popular so there is a large aftermarket that can supply just about everything.
You also need to decide how your car will be used: daily driver, weekends only, custom show car, NCRS stock, racing, etc. This decision will impact your restoration costs and your choice of engines, transmissions, ...
This decision may also influence your choice of year. For example: 1974 was the last of the stock Big Block cars (427/454), 1980 (except for the 305 ci California cars) were the last of the non-computer controlled cars.
Internally these cars are very similar year-to-year. If you want to put a big block 427 ci motor with 4 speed transmission, in your 1982 you can do it, even though the 1982 only came from the factory with a 350 ci and automatic.
Most of these cars are pretty straight forward to work on. Doing restoration work yourself will save $$$.
Take your time and look at lots of cars, you'll find the right one.
Are U mechanical or have any friends who are? The 75 and later sharks are all hampered by stock emmissions crap which hampered their horsepower. If U want U could pick up a very clean 75 or later car and depending on the emmissions laws in your state, build the cars engine up to much higher horsepower levels by removing said emmissions gear and/or adding bolt-ons for power. I have true dual exhuast and an edelbrock manifold and thats all i needed to make the car fun to drive( mid 15's in the 1/4 mile but the previous owner claims a 14.9 best). However, a cam and new heads will give me that over-the-top "true Corvette" performance that the cars looks demand.
Just figure out how much U want to spend, then choose a body style. Next decide what level and type of performance U want from your shark and go for it!!!
In 68 small block engines were 327 cubic inches with 350hp output and three versions of the 427 with power outputs ranging from 390hp to 435hp. They also had a virtual racecar engine designated the L-88 which had an output of 500hp but chevy advertised this engine at 435hp to discourage the average driver from purchasing it. It is a highly sought out engine option for the Corvette enthusiast. The 69 model had the small block engine punched out to 350ci. It had power putputs from 350hp, and 300hp, the 327 was also offered. BB engines ranged from 395hp-435hp and the L-88 engine.
During this model year Chevy produced the aluminun block ZL-1 which is the aluminum version of the L-88 engine and also had an output of 500+hp. Only two corvettes exist with this engine option. In 1970 the corvette had produced a SB engine rated at 370hp and was designated the LT-1.
Both of the high output engines in the SB family and the BB family had solid lifters, transistorized ignition and are easily identified by the characteristic hood bulge. The BB family of engines of the 68 and 69 model years sported this hood bulge. The SB LT-1 also sported this hood bulge likes its BB brother and also had solid lifters and the transisterized ignition. During the 70 model year the base SB engine put out 300hp and another version put out 350hp. The LT-1 engine corvette is identified externally with a decal that outlines the hood bulge and has the letters LT-1 on it. The BB engine of the 70 model year was punched out to 454 cubic inches. The SB LT-1 engine was in production from 1970 to 1972 with the 70 engine leading with 370hp, 71 engine 330hp and the 72, 295hp. From 1972 on, engine power had taken a beating due to the emissions laws the goverment put in place. The 68-72 Corvette also had chrome bumpers at the front and rear of the vehicle thus they are called 'chrome bumper vettes' and are largely sought by enthusiasts to to this destinction of looks and performance. The corvettes in this series also had egg crate pattern grilles from 68-72. The side louvers on the 70-72 vehicle were done in the egg crate pattern. In 1973 the goverment put into law a 5mph crash rule and the chrome bumper disappeared from the front of the Corvette but remained on the rear. Chevy offered two versions of it's small block engines. The performance engine was designated the L-82 replacing the now deleted solid lifter LT-1. Its BB brethern was still 454ci but horsepower decreased dramatically. In 74 the chrome bumpers in the rear disappeared. 1974 also marked the end of the big block engine. In 1975 the convertible(which was offered as an option since 1968) made it's last appearance. 1976 corvettes had a steel plated floor pan to help dissipate heat from the enging/drivetrain. This was also the last year for the 'stingray' script on the fenders-supposedly. Early 77 vettes had the stingray script but was replaced with a pair of crossed flags. 78 vettes had a redesigned interior with a real glove box-a sorely needed item and the fastback glass giving the vehicle a feeling of roominess. Chevy offered a 25th anniversary edition of the corvette and it was the pace car for the Indy 500.
There were really no major changes to the corvette in 1979 however more corvettes were sold in 1979 than anyother year previously( the 1992 model year tied this record) In 1980 the corvettes weight was reduced a few pounds by raking the grill slightly backward giving the car a drag cofficient of 84 (I believe this is correct) the speedo only read 85mph(the speedo read 140 in 1978-79 and 160 from 68-77) The 81 corvette had introduced a fiberglass rear leaf spring and the introduction of computer control. The 82 vette was the most expensive of all vehicles form this generation with the introduction of the vaunted 'crossfire injection'. The collectors edition of the 82 model year featured a 'hatchback' rear glass in which the rear glass opened like a hatch back. I hope this helps you a little and Im sure that if theres anything I have left out someone will either add to or correct me if Im wrong on some of the above information. :yesnod:
[Modified by Oldguard 7, 11:51 PM 12/1/2002]
http://www.corvettefaq.com
Lots of great info! :cheers:
The 69 model had the small block engine punched out to 350ci...
...In 1980 the corvettes weight was reduced a few pounds by raking the grill slightly backward giving the car a drag cofficient of 84 (I believe this is correct)
Very good. :cheers: Here's some for you.
punched means bored so should be:
...small block engine stroked to 350ci ...
BB engine of the 70 model year was stroked to 454 cubic inches. ...
CD would be close if reversed.
:cool:
http://search.barnesandnoble.com/boo...sbn=0760306575
Otherwise, great summary! :cheers:
Man, what a great dissertation! You should get some extra post points or something for the thorough job you did with your reply. :thumbs:
Welcome to the Forum :cheers:
Chuck
