HEI distributor plug wire order?
Old Dec 1, 2002 | 05:26 PM
Smokehouse69's Avatar
Smokehouse69
Cruise-In VI Veteran
Cruise-In VII Veteran
Default HEI distributor plug wire order?
I'm trying to fire up my ZZ4 for the first time this afternoon, and it will only pop and backfire through the carburetor. I think I might have the plug wires in the wrong order, since I can't believe the timing would be that far out directly from the factory.
Currently I have my distributor wired so that the wires are as follows.
The Number 1 wire is in the socket right even with the front edge of the vacuum advance canister.
Then moving clockwise around the distributor 8, 4, 3, 6, 5, 7, 2 is this correct or am I all messed up?
Old Dec 1, 2002 | 05:30 PM
PatsLs1vette's Avatar
PatsLs1vette
Default Re: HEI distributor plug wire order? (Smokehouse69)
yes 1 8 4 3 6 5 7 2 and you can make number one wherever you want it to be as long as the rotor is pointing at that plug wire on the cap.
[Modified by patsnitrovette, 5:31 PM 12/1/2002]
Old Dec 1, 2002 | 05:35 PM
Smokehouse69
Default Re: HEI distributor plug wire order? (patsnitrovette)
Thanks, Pat I just needed to verify that I had not lost my mind and terminal dyslexia hadn't scrambled my vision. I guess I'll go back down to the garage and verify everything again and try and fire it up!
Old Dec 1, 2002 | 05:47 PM
PatsLs1vette
bring it back on top dead center and see where number one is.then go from there.
Old Dec 1, 2002 | 06:33 PM
Oldguard 7's Avatar
Oldguard 7
patsnitrovette is right. Take off your distributor cap and bump the engine until the #1 piston is at top dead center( on its compression stroke).Wherever the rotor is pointing this is where the #1 wire will go. (It is a good idea to mark the base of the distributor so when ever you have to replace the cap and rotor you will know when the #1 piston is at top dead center). Replace distributor cap. Once you route the #1 wire then route the wiresin the remaining of the firing order (8436752) in a counterclockwise direction. Keeping in mind that the drivers side bank has odd numbers and the passenger side has even numbers.
Old Dec 1, 2002 | 06:42 PM
Disco_Mike's Avatar
Disco_Mike
a small note. the firing order is stamped on the intake maknifold of my 79 L82. Dont know if this is the case for your motor. You might give a quick peak around.
To HEI distributor plug wire order?
