Radio turns itself off
Old Sep 11, 2020 | 06:48 PM
Damn Yankee's Avatar
Damn Yankee
Default Radio turns itself off
Riding along listening to the radio thinking life is good and radio stops playing.
Turn on off **** radio continues to play and then shuts down.
Any thoughts on what's my problem?
Old Sep 11, 2020 | 07:12 PM
GTR1999's Avatar
GTR1999
If you can't turn it on or it shuts off when you hit a bump it may be the on/off -volume pot. Obsolete part but you can remove and clean with radio cleaner- deoxit is the brand that works good. I shot a little down the stem, let it soak in, then turn it on/off several times and it worked. I should remove the pot and carefully open it up to clean it with the deoxit.
You can check the wiring connector but I suspect that is ok since you can turn in back on.
Old Sep 11, 2020 | 07:37 PM
Richard454's Avatar
Richard454
IF -it's an aftermarket radio....educated guess...
You have a bad speaker - a shorting voice coil. The radio's output heats up and the protection circuit come on shut down the audio amp section- radio will stay lit but no sound.
When you turn the **** off and on it'll reset the protection circuit.
Richard
Old Sep 12, 2020 | 01:26 AM
7T1vette's Avatar
7T1vette
You have entered the "Twilight Zone" or your car is related to Christine....
Well, maybe not...........
To Radio turns itself off
