'74 engine harness
Old Dec 2, 2002 | 06:01 PM
Teuffelhunde's Avatar
Teuffelhunde
Default '74 engine harness
Should it matter whether the car is automatic or manual when buying an engine harness? I can't see why it would. Thanks in advance
Old Dec 2, 2002 | 06:09 PM
mayberg's Avatar
mayberg
Default Re: '74 engine harness (Teuffelhunde)
You do have the electrical connection for the kick-down thingy on the TH400 that you probably wouldn't have for a 4-speed. It's operated off the same switch (I think) as the cowl induction flapper door thingy. GM
Old Dec 2, 2002 | 06:11 PM
vettfixr's Avatar
vettfixr
Yes, there is a difference. A 4 speed car has a harness that interfaces with the TCS system. There's a sensor on the tranny, a vacuum controller on the intake manifold and the wiring for the temperature sensor in the rear of the right hand head. I believe an automatic is different at least from the point of not having the sensor wiring for the tranny.
To '74 engine harness
