Blinker issues
Old Sep 17, 2020 | 10:19 PM
Chad87's Avatar
Chad87
3rd Gear
Default Blinker issues
I have a 1975 Vette that is having issues with the blinker. Both rear blinkers work and so do the flashers. But when I pull the headlight switch my driver's side rear doesn't work. Light on the dash for the blinker comes on as well. I have changed the blinker relay thinking that was the issue, but it wasn't. Don't know if I have a wiring issue or it's something simple. Just looking to get pointed in the right direction on what to look for with trying to figure this out. Any help is appreciated, thanks!
Old Sep 18, 2020 | 06:51 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Have you checked the bulb?
Old Sep 18, 2020 | 07:26 AM
Chad87's Avatar
Chad87
3rd Gear
Yes the bulb works.
Old Sep 18, 2020 | 10:02 AM
henrikse's Avatar
henrikse
It will be a ground issue. When something likes this happens it is searching for a ground thru some other bulb or source. I would take apart the grounds for rear and headlight switch clean down to see good clean including eye and bolt reinstall and try again
Old Sep 18, 2020 | 10:28 AM
Chad87's Avatar
Chad87
3rd Gear
The rear taillight bulb is good. I tried the other side that is working in the driver's side to verify. I also have replaced the headlight switch thinking that could've been there cause.
Old Sep 18, 2020 | 10:52 AM
henrikse's Avatar
henrikse
The ground for headlight switch is on righ hand pillar way up and ground for rear lights is on frame by rear tire carrier I believe. Take these apart and clean up good down to metal and check eye and reinstall
Old Sep 18, 2020 | 10:53 AM
Peterbuilt's Avatar
Peterbuilt
Default Hi and welcome!
Attach a wire to a good ground and touch the other end to the brass bulb holder if the bulb works correctly replace the socket.
Old Sep 18, 2020 | 11:07 AM
Richard454's Avatar
Richard454
I'd also see if you have the hazard switch is sort of half pulled out.
Richard
To Blinker issues
