Slightly Worn Spindle feedback requested
One spindle appears slightly worn with a step where the inner wheel bearing goes.
The step is definately larger in the loaded direction (vertically) and primarily on the lower loaded side as you would expect.
Shaft diameters 1.3745 & 1.3735 on one, and 1.3735 & 1.3725 on other.
1.3750 Timken bearing inner diameter.
After researching this for an hour or more Timken recommends the shaft be .0005 to .0015 smaller than the bearing for a slip fit.
That would be 0.5 to 1.5 thousandths clearance recommended.
I have almost exactly that on the one spindle with no finger lip felt at all.
On the other one I have 1.5 to 2.5 thou clearance.
I am uncomfortable leaving it "as-is" (OCD kicking in maybe?) (Too many hipo engine builds?)
This Loctite 641 product is recommended for such applications.
It is removeable for service use.
It tolerates 300 degrees.
It fills a gap of up to 4.0 thou.
What do you think?
Anyone else with any experience with this?
I read if you run it with too much spindle wear, the bearings will frequently wear them selves loose and need to be frequently readjusted. In one guys case every couple thousand miles. At least until bad things happen!
What do you think of the Loctite repair?
(That's what it says it is made for.)
Or should I try to find an undamaged 42 year old spindle?
After researching this for an hour or more Timken recommends the shaft be .0005 to .00015 smaller than the bearing for a slip fit.
What do you think?
1. In my opinion, the spindle OD is there to center the bearing and is not the primary force to restrain it. If that is the case the worst that can happen is your wheel will be and additional.0005" off center
2. Most of the anti-rotation force is going to come from the horizontal load imposed by the taper on the bearing driving it into the seal shoulder or the keyed washer, when the wheel is put on the ground. ( loaded by the weight of then car)
3. As for the loctite 641, it is an adhesive and It will make future disassembly difficult so I would avoid it if I didn't really need it.
What issues do you anticipate if you run it as-is?
If the ridge doesn't catch your fingernail, polish it out with some 220 in a shoe-shine motion and put it together and check.
If it catches your nail, well....
With the spindle worn like that, you can set the bearing preload, but the actual "play" that you feel when you grab the wheel at the 6 and 12 o'clock will not be actual bearing clearance, but a combination of bearing clearance, and bearing race movement on the spindle.
If after repeated attempts, and the bearing play is still too much, bearing mount is an option, but I would spring for a new spindle...
If, when you put it together, you are satisfied with the wheel movement, run it. But be alert for changes in the way it steers.
Good luck
Jeff
Good luck
Jeff
Yes it definately catches my nail. It is on the bottom only, from a previous dry spinning bearing. It's not too bad, but there is 2.5 thou clearance where it is supposed to be 1.0
So my bearings and rotors will have at least 2.5 thou movement.
What was the rotor spec? Shouldn't it be 1.5 thou or less?
Tom
Rotor run-out could certainly be affected.
My next question is how were the brakes ? Did you have any pulsation ? How about steering issues ? Shimmy ? Pulls ? Etc...
If you had no complaints, then put it together and run it.
If there were driveability issues, then it's time to spend some money.
Ymmv.
Jeff
It came home on a trailer. Powered it up just long enough to get it into the garage and tear it down.
Not much consensus here.
Going to check with my machinist friend and see what he says.
May just buy a spindle to alleviate my worry-wort tendencies....
Yeah I would kind of expect some kind of brake issue to show up with these fixed calipers. Even if it is just leaky caliper seals. That wobbling has to cause some kind of issue....
But he agreed with me that 2.5 thou there will cause about 4 times that at the wheel. So that's over 10 thou. And the wheel bearings need to be adjusted a little loose anyway, so that adds more. But chevy's spec is only .001 to .008 wobble at the tire. So since I will be significantly over that, and maybe double, i'm just gonna replace it. There has got to be some kind of brake issue it would cause, since the calipers cannot move. Besides it's only $75 locally.
A lot of this would be sooo much easier if I just had an opportunity to drive the car before I took it apart, and decide what worked well, and what didn't. But it didn't run well enough for that.
Now I just have to guess and inspect everything! YUK!
Next time I'll know better.....just I just say next time?
I looked up the price of spindles and saw reconditioned ones from $75 (eBay) to $215 (Ecklers). There was no description of what "reconditioned" meant. From past experiences, when I see the words "reconditioned" ,"Remanufactured", or "warranty" I get nervous and wonder what I a getting. .
One less thing to worry about.
It was easier to do that than assemble the spindle/rotor/wheel and measure the slop, especially being off the car.
If I would have had to go to E-Bay I might have done it differently.
I have so many experts available within 30 min of here, I'm counting my blessings. I'm in the middle of the heavily populated North-East corridor between Philly and NYC.
I can't imagine trying to do this in some place like...Belgium, England or Australia!!!
I really feel for your guys!
I'm no slouch but I certainly do not have all the expertise I need to do this frame-off all by myself.
Thank all of you for your help!
As point goes in, it also displaces steel & raises a "crater wall. " Similar to a machine shop's "Knurl" which may be another option.
