Bad Brakes
I can have someone assist in pumping the pedal while I go around all 4 wheels and bleed. There is always a firmer (acceptable) pedal when I do this. However when I start the car pedal goes back to floor. M/C was bench bled and I bled it on the car. I have plenty of vacuum. Rotors are smooth and I don't think runout is a possibility.
I can't even find anyone who even wants to look at my car now. This started in March and I have about 1000 bucks invested. Any advice is appreciated.
Did you ever answer the question about checking the booster pushrod to master clearance?
Did you disconnect the brake lines at the master, plug the ports, and check if the pedal still goes down?
https://www.corvetteforum.com/forums/c3-tech-performance/4435917-position-of-rear-bleeders-2.html#post1602093046
I have a '76, and have replaced the flex hoses, master cylinder and front pads while doing a minor restoration when I bought it. I've done exactly the same things you have, plus, using a pressure bleeder, (twice), checking the proportioning valve, checking the booster, and then resorted to dancing around the car and chanting. Still no brakes with the engine running and the booster engaged.
Of the dozen or more cars I've done serious work on, including full restorations, I have never met up with anything like it. I'm seriously starting to wish I'd never bought the car, I'm sick of it. Working on it has become a chore instead of a hobby.
I'm starting again tomorrow afternoon, trying a few new things that came up in this forum and popped into my head in the middle of the night.
Anything I come up with that helps, I'll post it on your thread right away, guaranteed.
If you aren't pulling air into the calipers, you might have a bad master cylinder, or incorrect pushrod clearance as previously mentioned.
The suggestion to disconnect the brake lines and plug the master cylinder is a good one. If you do that, and pedal still goes to the floor, you know thare where your problem is located.
"stomp" the pedal and that may aid in removing air. Yes I bought a vacuum bleeder Pumped that sucker a hundred times. Why would runout be an issue if you have a good pedal then it went to the floor when you start car???
Do I just use pipe plugs to block the M/C? I'll check Amazon for the tool you mention.
You have to ask.
Yes a pipe plug with correct size/thread will work.
You changed a bunch of parts and had multiple people work on the car - its a shot in the dark as far as what's wrong - folks are just trying to come up with all possible reasons to help you out.
Why not start with the simplest thing that was suggested - block all the lines to your M/C and then test. That isolates it down to just your booster and M/C.
I mentioned runout issues because that's what I experienced, but it was after I would bleed and get a firm pedal and then drive the car for a short while.
I get better info from you guys than the people I pay. Thanks all.
I can't see anywhere in the thread what the pedal feel is like with the engine off. If the pedal is hard with the engine not running the issue is not air in the system. JMPO
$45.99
It's what I purchased and used. You have to fiddle around with it to get it to set just right, but I was able to use it to measure runout on the front and rear.
But it sounds like you need to start with isolating the master cylinder from the rest of the system and starting there first, based on what you've described.
Did you get, or make, a pressure bleeder? I don't even try to bleed my corvette brakes without a pressure bleeder.
Good luck I hope you can resolve the issue!
