Lower Control Arm and bent shaft help
The RH shaft was bent once I could take a look at it away from the arm.....see below. Had a real hard time getting this shaft off the mounting bolt that attaches it to the frame as well. Rust was an obvious problem as well.
So, I started looking at the RH Lower Control Arm to see if it was bent or off-shape as well. From what I can see, it doesn't look TOO bad. It looks like there is a slight turn in, but most of it appears flush/consistent with the LH Arm. The bushing holes on the RH Arm have a little bit of warping in some spots, but it doesn't seem really damaged overall. The gaps between the Arm bushing holes seem OK as well.
One thing that caught my eye was the mounting bracket on the RH side on the frame. (BTW, I rust-coated the frame before I discovered these issues). It doesn't appear as "true" or straight as the LH bracket. Also, the mounting bolt hole is off-center compared to the LH bracket hole. I may be wrong, but it almost looks like it was off from the factory. Either way, it must have had a hit with a curb/rock/etc at some point in the past. I also see the RH Rear shims have several more than at any other corner.
Basically, I plan to get two new Arm Shafts for both Control Arms no matter what. I gacked the LH shaft end when trying to move the inner bushing sleeve. Rust is bad there, too. But, I was wondering if someone could take a look at the Arms themselves and see if there are any noticeable trouble spots. Or, if you have any other input or advice, I'd really appreciate it. Pics are below......................Thanks!!!
LH Mounting Bracket
RH Mounting Bracket
LH and RH Lower Control Arms
Rear bushing brackets up close
Shims as they were prior to disassembly
I've also been looking at new upper shafts in case it's best to do that. Been reading old forum posts on offset shafts and wanted to get thoughts on doing this instead of the straight OE set up. Pics are below of the current shafts, current shims & width of each and also one of the lower shaft cup-washers. The knurling is mostly ground down and obviously grew a lot of rust.
1. Should I get new Upper Arm Shafts??
2. If so, should I go with Offsets??
3. Should I just get an all new bolt kit to have proper knurling on everything??
This project has definitely been a learning experience........I laugh now when I thought I would hammer it all out in 1 1/2 weeks before a car show earlier this month.
Upper Control Arm Shaft end
Current Shims as they were
Lower Control Arm Shaft washer
Basically, I don't the alignment shop to call and say "You should have stuck with OE shafts".
On the other hand, if the offset orientation is completely wrong after I do the install, I suppose they could just flip it and work from there.
