Courtesy light delay feature 79 question
Old Feb 25, 2022 | 01:55 AM
Maxim0's Avatar
Maxim0
[QUOTE=interpon;1602215023]Hi, was reading in another thread about battery drain and courtesy delay came up..
back story I’ve previously fried a tach, and have never really found the issue for erratic tach sometimes with ignition on etc..
i also had great help here checking grounds cranking etc thread to no smoking gun..
so to my question..
my courtesy light works fine including the spare tire area..
also works on and off with headlight switch..
but it has no delay (which i never knew til today) and then obviously no shut off with ignition on..
it never did since i had it. Reading threads its like its bypassed..it is not..looks original.
i also replaced the dome light with led as i never liked how hot those get...worked fine once I installed correct direction..but here’s something weird..when i click off key the ignition from running or not..the led flashes for just a very brief split second.
with regular bulb it does not...
i dont see anything but wondered after reading all the threads that it could fail like its bypassed? Anything to measure? I have a dmm..
Old Feb 25, 2022 | 02:00 AM
Maxim0's Avatar
Maxim0
so to my question..
ill go ahead and try the willcox board...
thanks for input..
the transistor to be replaced is this on the photo, with this abbreviation and numbers. it works great.
Old Feb 25, 2022 | 02:11 AM
Maxim0's Avatar
Maxim0
so to my question..
thanks for input..
Old Feb 25, 2022 | 08:33 AM
interpon's Avatar
interpon
great find , thank you! i think i still have the old one to play with
https://www.digikey.com/en/products/...UaAgzLEALw_wcB
