Tom Dewitt Help needed
Questions
1. Can you tell me the air flow of the original 7 blade mech fan at 700 RPM?
2. How does this compare with the twin SPAL setup's air flow?
3. It appears the SPAL fans have a 2780 CFM flow. This appears to be the equivalent of a 10 MPH wind flow though my old radiator. Since the electric fans are a constant speed, do they provide any benefit when the car is moving over about 10 to 20 MPH?
4. I had the old brass/copper radiator. DeWitt offers two Aluminum radiators, a 1" wide tube radiator and a 1-1/4" wide tube radiator. Can you tell me the heat transfer efficiency differences between the three?
5. From all the posts I read here, it appears you major competition is Champion. How does your heat transfer compare to theirs?
6. From time to time DeWitt has a 15% off sale. Can you leak that date? Pun intended.
Thanks in advance for any help you can provide.
Questions
