Quadrajet cleaning
Old Oct 1, 2020 | 08:27 PM
thelal1's Avatar
thelal1
Default Quadrajet cleaning
What is the best solution when soaking quadrajet parts in for cleaning before reassembling?
ted
Old Oct 1, 2020 | 10:37 PM
Shark Racer's Avatar
Shark Racer
I’m in CA, have had good like with Berryman Chem-Dip.
You can use the parts tray for small parts, but the airhorn / main body / throttle body need to be done in an aluminum pan. So I stick them in a pan, turn them over after a bit, then pull them out, rinse and blow through passages with compressed air.
Ultrasonic cleaners and larger parts baths are good too, I just don’t have the resources.
If your parts have paint, it will ruin whatever solution you use and take all the paint off, so you want to be mindful of that.
Old Oct 2, 2020 | 07:44 AM
Jebbysan's Avatar
Jebbysan
Dr. Detroit
I have a 5 gal Berryman Chem-Dip as well......best stuff there is but getting harder to find and $$$$$$. I hang the part off the side with coat hangers and smack the lid on. This stuff is the stinkiest **** on planet earth....and if you get it on your skin.....even a drop, you will stink for days. You have been warned LOL.
But....if the unit is not that bad....I use my 9 litre Ultrasonic cleaner. I "cook" it for 90 minutes at 80 degrees Celcius. Immediately after pulling it out, I spray with Berryman Carb spray....DO NOT WAIT! I use distilled water, Dawn, and a shot of Lemon Juice......I have been using this bio safe concoction for ten years and do many vintage bike carbs this way....they brighten up very nicely.
Jebby
Old Oct 2, 2020 | 10:15 AM
Dynra Rockets's Avatar
Dynra Rockets
I used a Pinesol soak overnight. Came out great
Old Oct 3, 2020 | 08:39 PM
fake's Avatar
fake
Napa has a gallon can of panther **** i use it stinks , gives you a head ache and is not a good **** tail mix, do not buy it. $30.00
To Quadrajet cleaning
