68-79 vs 80-82 Diff mount?
Old Oct 3, 2020 | 12:49 AM
ChrisLSx's Avatar
ChrisLSx
Default 68-79 vs 80-82 Diff mount?
Which is better, the 68-79 crossmember style mount or the 80-82 bat wing style mount?
It would seem to me that the earlier style would be stronger and stiffen the frame more (particularly if the rubber bushings were replaced with aluminum or steel) since it can serve as another frame member.
note:
I’m asking about the mount, not the diff itself. I’m full aware that the iron diff is stronger (but heavier).
Old Oct 3, 2020 | 08:33 AM
GTR1999's Avatar
GTR1999
The iron mount and diff are stronger
Old Oct 3, 2020 | 09:49 AM
Dynra Rockets's Avatar
Dynra Rockets
Not really, even with solid bushings the diff crossmember is bolted to a welded lateral beam so none to negligible additional frame stiffening.
I like that the batwing design is substantially lighter. If I was going to modify my frame anyway I would put the C4 unit in from a stick (dana 44) and then add more gussets and stiffeners per the Chevy power book
To 68-79 vs 80-82 Diff mount?
