79 tech calibraition
Old Oct 3, 2020 | 02:30 PM
speedsecret's Avatar
speedsecret
Default 79 tech calibraition
Just changed my techometer circuit board on my 79
now its working but i found out that when i turn the switch on the needle seats a little under the 0
so i assume that when the engine running its read lower numbers then the engine actually runs
Shouled i pull the neddle out turn the switch on to get the proper zero and put the neddle back or i need to calibrate from the potentiomeeter on the circuit board?
kind regards
Tom
Old Oct 3, 2020 | 02:47 PM
Cmurray79's Avatar
Cmurray79
I would retry setting it to 0 with the ignition on.
Old Oct 3, 2020 | 02:59 PM
speedsecret
ok but how? From the circuit board?
Old Oct 3, 2020 | 03:19 PM
MelWff's Avatar
MelWff
Watch the video
Old Oct 3, 2020 | 03:39 PM
interpon's Avatar
interpon
Yup clear directions ..i got the willcox board and it fixed my tach and yes you need to zero it with voltage..
for whatever reason mine very slowly drops from cold accurate zero reading to drop about 4-500 rpm off at idle low..when running or ignition on..still have not figured it out.
Old Oct 3, 2020 | 06:07 PM
speedsecret
After watching the video its seems like i have to place the needle to zero
will try it tommorw
thanks
To 79 tech calibraition
