Taking lens off frame T top
Old Oct 6, 2020 | 06:14 PM
RockyL32's Avatar
RockyL32
From: If your not the lead dog the view never changes Boise, Id
Default Taking lens off frame T top
I have a set of T tops where the glass is good but they seem to be separating from the frame. They whistle and I can move the frame away from the glass by pushing on it. Has anyone taken the lenses off the frames and resealed them? Any directions floating around?
Thank you
Old Oct 7, 2020 | 07:04 PM
Yadkin's Avatar
Yadkin
It's been a while since I put new seals in mine but as I recall the lass is glued on, like all modern windshields. An automotive glass shop should be able to do the repair for you.
Old Oct 7, 2020 | 07:26 PM
RockyL32's Avatar
RockyL32
Thank you, I didn’t think about a glass shop. I’ll give them a call. I did purchase a windshield removal tool thought I would give that a shot then maybe some 3m windshield adhesive.
Old Oct 7, 2020 | 07:43 PM
Yadkin's Avatar
Yadkin
I can fix just about anything but I draw the line at glass. Oh, I'll replace bolted in door glass but not a rubber-sealed windshield. And definitely not glued in glass. Shops have special tools, chemicals and expertise that I don't have. And I've broken glass before- not fun.
Old Oct 9, 2020 | 10:56 AM
RockyL32's Avatar
RockyL32
Well glass shops politely declined to do the work so I started. I bought a windshield removal tool from Harbor Freight, the one with a cable and 2 handles. Came apart pretty easy. I’m going to clean both the frame and glass. Paint the frame.There are 4 alignment studs I will reattach to the glass using rear view mirror epoxy. And glue the assembly back together with 3M windshield weld. Fingers crossed
Old Oct 9, 2020 | 12:55 PM
Yadkin's Avatar
Yadkin
Lining up is the issue. Can you test fit on the car before gluing down? You can always mark the exact positions by using masking tape. Good luck.
To Taking lens off frame T top
