tyre size please
Old Oct 10, 2020 | 02:00 PM
trans am kev's Avatar
trans am kev
Default tyre size please
hello .can i put 255/60/15 on all 4 corners of my 82 with the standard alloys . it will be lowered by around 1.5" looking at buying the cooper cobra tyres . cheers kev
Old Oct 10, 2020 | 04:56 PM
4-vettes's Avatar
4-vettes
Cruise-In VIII Veteran
Yes, absolutely!
255/60-15's all the way around my 77 also sitting slightly lowered. Speedo reads perfect. Been running 255/60-15's all the way around for over 30years.
Old Oct 10, 2020 | 05:02 PM
trans am kev
thanks for the reply even with the different style of front lower panel
Old Oct 10, 2020 | 05:38 PM
4-vettes's Avatar
4-vettes
Yes. The wheel opening is still the same. Over the years I've been in 3 different Corvette clubs in 2 country's. Known a lot of 80-82 corvette owners running 255/60-15's
Old Oct 10, 2020 | 06:04 PM
Kacyc3's Avatar
Kacyc3
That is the factory size tire.
Old Oct 11, 2020 | 03:12 AM
trans am kev
thank you very much for the replays . could i go wider on the back if i cut the parking brake bracket from the arm and weld it on the top
Old Oct 11, 2020 | 04:07 AM
4-vettes's Avatar
4-vettes
On the Stock wheels?? Wouldn't recommend that.
Old Oct 11, 2020 | 11:53 AM
trans am kev
yes there stock so will stay with the 255/60 thanks for the help . cheers kev
Old Oct 11, 2020 | 04:40 PM
m and t's77's Avatar
m and t's77
On a 15x8 rim it won't be a problem.Have that set up on my rally rims.
Old Oct 11, 2020 | 06:07 PM
trans am kev
have you cut the brackets off and welded them on the top .do you now what is the biggest tyre i can fit it will be lowered abought 1.5"
Old Oct 13, 2020 | 03:41 PM
drwet's Avatar
drwet
Not sure about the '82 but putting 255-60/15 tires on a '79 requires cutting the wheel wells. They were available as an option from the factory, but when they were installed the wheel wells were relieved at the back on the assembly line to make room for the tires. Its not a huge cut, but it is required to keep the tires from hitting the body when turning. I did the modification on my '79 when I installed the 255's, according to the specifications in the factory assembly manual.
Old Oct 15, 2020 | 02:18 PM
trans am kev
thanks for that could i fit the 255 on the rear and 245 up front car will be lowered around 1.5"
Old Oct 15, 2020 | 04:02 PM
drwet's Avatar
drwet
I don’t think you’ll have a problem on the back. Not sure about the 245’s on the front. It’s a relatively minor trim to the wheel well at the back on the inside if it’s required.
Old Oct 15, 2020 | 05:37 PM
DarrellD23's Avatar
DarrellD23
Brand new Cooper tires 255/60/15 not lowered
Old Oct 15, 2020 | 07:03 PM
Mooser's Avatar
Mooser
Not related to the thread but that's a good looking car
M
Old Oct 15, 2020 | 07:27 PM
trans am kev
just what i wanted to see are they 255 all round like the stance
Old Oct 15, 2020 | 07:34 PM
DarrellD23's Avatar
DarrellD23
Same size on all four.
Old Oct 16, 2020 | 01:06 PM
trans am kev
will go with the cooper cobra 255/60/15 and probably not lower if it looks like yours once i have done . thanks for every ones help cheers kev
To tyre size please
