New heads for a 72 350 base engine
I might be the exception, but i stick with my 'buy quality and bigger than you need now' mindset. I cannot count how many times i've heard guys saying 'Yeah... i wish i'd bought the bigger heads'... the second they take their engines apart for a rebuild/refresh. EVERY time. I dont mean 225cc monsters... just... not the entry level. Its like building a smaller shop... you always regret it down the road. Or... you'll just end up buying another pair ov heads (some people dont mind spending money). I'm too cheap and poor to not plan ahead.
personally I've had mine for over 30 years. The OP sounds about the same if not having his car even longer.
thinking if we wanted to build HUGE power and break things, we would have done that when we were much younger.
I ripped out enough U joints went I was younger.
Now it's time for car shows and cruises.
sounds like this maybe is where the OP is more or less. Just looking for a reliable driver. Would like to stop the smoke at startup
and thinking the original heads are most likely not really worth fixing up. And maybe in the process gain a bit, but not looking to go crazy. Well at least that what I have gotten out of his posts.
Shoot for future more power? Think harder about the original post and question.
Rant over.
The OPs first comment gave me the impression hes not really looking for anything crazy as far as heads but figures if im going to replace my factory heads, why not kill two bird with one stone as long as it doesnt cost too much. which is why I linked new budget heads others have had good luck with. those are the "pro comp" type castings which have been around a long time now and have been improved. Nothing spectacular but certainly an improvement over stock.
As for bigger heads... The issue for me would have been if I had gone with anything bigger than 180 heads on my 355 and then lost port velocity. Because how often do you think people do what your suggesting and buy parts that are a mismatch for their current combo and drive a dog around unsatisfied only to lose interest or never get around to doing bigger or better things with their engine? I think if a person is going to consider heads with larger intake runners he or she would want to be very sure there are more upgrades coming to support them. Its no different than a noob putting way too big of a cam in their first engine and wondering why the car cant get out of its own way. All things in time and at the proper time is the best route.
looks like the TFS come with a 60cc chamber which would bump a L48 in the 9.5 ish of compression ratio
Beware of cheap heads.....it is not so much the casting and parts but how they are put together......I would never run a cheap head as assembled, in fact I will not by an assembled head period after what I have seen in the performance industry...that goes for Dart, Brodix, AFR etc......I urge you to buy bare castings with valve job and assemble yourself or have them done professionally. And twenty guys here will tell you that they had no problems with pre-assembled stuff, that's great....but do you want to be the guy whose heads were assembled on Friday afternoon at 3:30 by a 21 year old pothead named Seth?
The Trick Flows my customer bought are assembled, but he pulled them apart to paint them, and I told him to leave them that way.......I will not bolt them to an engine unless guide clearance, valve lap, and install heights are all checked.....as well as if the valve seals are worth a **** (you would be surprised).
I would not hesitate to bolt a pair of these to your engine........we are using the Performer EPS.
Jebby
Jebby
https://dartheads.com/iron-eagle-23-165cc-s-s-heads/
Jebby
Those 500 heads...I wouldnt. A half decent valve train setup will run you 400+ they cant be putting anything good in there.
Did that many yrs ago with a 350..figured 200cc wasnt that big. Hardly any difference from the 462 I was pissed.
I had them ported thinking that would fix it. Now they were 230cc (on a 350 you can figure out the rest). Wasnt til I saw the flow sheet I saw the note they poured 215 out of the box. Thanks Dart.
Long story short I assmbled a radical sounding turd. It was SO slow...
I cheaped out..coulda waited 2 mos for the new AFRs and probably been happy with the 350.
The engine they are on today pulls super hardprobably makes decent hp..not as much torque as with one of todays heads. Oh well!
These dynos on YT dont show part throttle driveablility, low end torque, throttle response only WOT #s and flow #s to sell sponsored parts. Easy to get sucked up in that and build a poor performer.
https://www.compcams.com/xe268h
They are what I run.
EPS is the perfect intake for that
If I could round up funds to do a carb legal 383 for my 88 Id gladly sell the 113s..
Jebby
Are the stock pistons close enough to the deck to get quench...???
