Carb choke coil question
Lars
Its a 1978 std not the higher hp version.
The rebuild you did on the carb several years ago is still working great. I just cannot seem to get the choke setting dialed in. I don't know what kind of carb, I thought they probably all got the same one in 78. If they didn't I'll look for some kind of identifying tags or numbers on it.
The 1978 uses a hot air choke, and the operation is dependent on a proper hot air supply to the choke. If I remember right, your carb had indications of someone not getting the choke to operate correctly before, because your carb had the choke pulloff removed along with the airvalve linkage. The choke intermediate rod was also disconnected.
Questions and issues would be:
- Do you have both hot air tubes hooked up?
- Are you running a stock intake manifold with open (not block-off) manifold gaskets?
- Is the heat exchanger in the manifold crossover intact?
- Is the heat exchanger open and unplugged so it can flow hot air?
- Does the choke housing get hot after 10 minutes of engine operation?
If you post up some photos of the choke side of the carb I may be able to spot the issue.
If all items are hooked up, and the choke housing is getting hot, you may have a defective hot air choke coil. It that's the case, I can send you a good used one to try out. Let me know.
Lars
I will take a look at those items that I can figure out what they are. I know that the ones that have anything to do with the cross over on the exhaust are not going to be there as I have side pipes. I did put baffles in each side pipe and had a cross over welded between then.
Lars
Lars
I drove the car until I was certain it had reached operating temperature and the temperature of all components had stabilized. After I drove into the garage, within 3 minutes I took the temperature of several components.
plastic cover on the choke 150f
housing behind the plastic 143f
top of the carb 125f
intake manifold 192f
exhaust manifold 525f
upper radiator hose connector on the intake manifold 210f
I found a picture of a 78 Vette engine and compared it to my setup. The major difference I saw was the EGR valve on mine is not connected to a vacuum switch. A couple of years ago I found that the EGR valve was defective so I replaced it. After I put the new one on the car ran very rough. I took the new one off and put the old one back on and the car ran well again. The old one, as I recall, had a vacuum leak and was completely frozen or rusted together internally.
