Engine bay
Old Nov 4, 2020 | 02:49 PM
Kevin Reyes's Avatar
Kevin Reyes
Default Engine bay
i just picked up a 1981 corvette and was wondering up to what cu. in. engine i can fit.
Old Nov 4, 2020 | 03:18 PM
4-vettes's Avatar
4-vettes
Cruise-In VIII Veteran
WOW. Just goggle engine swaps C3 Corvette. Just about everything has been put in these cars. I've seen V12's. Tons of big blocks. LS motors , the sky is pretty much the limit!
Old Nov 4, 2020 | 03:26 PM
Kevin Reyes
cause i want to put a 383 stroker but i was wondering if there would fitment issue and would i have to cut or weld anything
Old Nov 4, 2020 | 04:19 PM
resdoggie's Avatar
resdoggie
Had a 1976 L-82, 4-sp
Royal Canadian Navy
A 383 is just a stroked 350. So the engine dimensions are the same for the 383. No fitment issues per se. Select intake manifold/carb/air cleaner carefully so it can fit under the hood.
Old Nov 4, 2020 | 04:21 PM
Jokerb90's Avatar
Jokerb90
Search is your friend, click advanced, title only, enter 383.
but no, should not require cutting or welding for a 383.
Old Nov 5, 2020 | 06:18 AM
Rescue Rogers's Avatar
Rescue Rogers
Is my vette stock?? HAHA
2016 C3 of Year Finalist
Just the height of the carb and air filter is the only issue and that is on every motor. If you use a higher intake and spacers then you need a drop base air cleaner. Just make sure it clears the throttle linkage and the type of choke you have
To Engine bay
