Vacuum line touching valve cover
Old Nov 10, 2020 | 09:35 AM
my1970conv's Avatar
my1970conv
Default Vacuum line touching valve cover
Hi,
Just curious if anyone has a picture similar to the one below of their engine... mine's a 1970 350/300hp. There appears to be a couple of vacuum hoses which go from the solenoid/spark control to likely the distributor and carb... the hoses are touching the valve cover, so I assume that that is not good, and the rubber hoses may develop a hole in them over time... I think I will try "prying" them a little further so they don't touch the valve cover, or maybe I can use some heat reflective tape to surround the hoses.
Anyhow, if someone has a good picture of this area of their engine bay (passenger side), I could compare to it.
Thanks...
Old Nov 10, 2020 | 10:38 AM
barkingrats's Avatar
barkingrats
1967 Pedal Car Champion
I'm not sure the valve cover heat is going to affect the hoses, but... If you pull the air cleaner assembly off, you may see a way to route just a little differently. Or, you could snip off the ends little by little to shorten and make the path straighter.
Old Nov 10, 2020 | 11:04 AM
lars's Avatar
lars
Originally Posted by my1970conv
I assume that that is not good, and the rubber hoses may develop a hole in them over time... maybe I can use some heat reflective tape to surround the hoses.
Completely irrelevant - a non-issue. They will never develop a hole over any amount of time. GM had several valve cover designs with vacuum hose clips on them that held the hoses tightly to the valve covers. A valve cover seldom gets above 180 degrees. Your rubber heater hoses run hotter than the surface temp of the valve cover...
Old Nov 10, 2020 | 11:37 AM
my1970conv's Avatar
my1970conv
Thanks Lars... I'll leave it as-is...
To Vacuum line touching valve cover
