Another Spindle question
Old Nov 11, 2020 | 06:24 PM
leigh1322's Avatar
leigh1322
Old Pro Solo Guy
Default Another Spindle question
Does removing the spindle necessarily ruin the bearing or races?
As in could you do it once on a brand new T-Arm?
Old Nov 11, 2020 | 07:04 PM
Petes73's Avatar
Petes73
Setting the end play on the bearing may take a couple of times to get right. I know mine did. Take your time and be careful.
Old Nov 11, 2020 | 07:26 PM
GTR1999's Avatar
GTR1999
It won't ruin the races but I wouldn't use the bearings if you drive them out. If the setup tool is used and correct endplay set then it shouldn't change on final install.
Old Nov 11, 2020 | 08:08 PM
leigh1322's Avatar
leigh1322
Old Pro Solo Guy
Thanks!
To Another Spindle question
