Charcoal can vacuum??
Old Nov 14, 2020 | 05:57 PM
eddp's Avatar
eddp
Default Charcoal can vacuum??
I deleted the ecm on my 81 and have a vacuum hose from the charcoal canister that was hooked up to the old qjet. I have left it unplugged, but want to plug it in to the manifold vacuum port (drivers side) on my Edelbrock carb. I'm guessing that it will pull fumes from the canister, which is still connected to the gas tank.
Is it possible that I will have to adjust timing and or carb with the cannister now hooked up?
Old Nov 14, 2020 | 08:25 PM
MelWff's Avatar
MelWff
Are the rest of the evap components still installed, see the diagram in the link. No need to adjust timing or mixture screws.
https://www.corvetteforum.com/forums...gram-help.html
