Dome lights
Old Nov 14, 2020 | 10:36 PM
truckerlary's Avatar
truckerlary
Default Dome lights
Trying to figure out how to make my dome lights come on in my 80 model. Will come on with the light switch but not when I open the door. Can anyone lead me in the direction of fixing this. Guessing the door switch is a ground.
Old Nov 15, 2020 | 09:55 AM
Mooser's Avatar
Mooser
Yes pretty much all the switches are grounds for these (and of course the ground needs to be run as a separate wire due to that whole fiberglass body thing...)
Sounds like the circuit works so I'd take a first look at the door switch. could be anything as simple as dirty contacts. I believe the 80 still has the courtesy switches at the front of the door jamb
First, try rotating the plunger back and forth a little ways while lightly pulling out on it, that might be enough to clean off the contact area. There are a few different styles of switches so don't spin it around in case it's one with the wires attached
Second, carefully pull the switch without rotating again and see if a wire isn't loose/off. Try grounding the contact with a jumper wire, that will hopefully tell you is the problem is at the switch or somewhere else
If you don't have a wiring diagram, check here to get one
https://www.corvetteforum.com/forums...or-anyone.html
M
Old Nov 15, 2020 | 10:03 AM
Eric P's Avatar
Eric P
You need the schematic because the door switches work together with a timer , the timer will leave the lights on for about 60 seconds after you shut the door
To Dome lights
