Condenser Bolt/Screw size help
Old Nov 15, 2020 | 12:47 PM
Kev73's Avatar
Kev73
Default Condenser Bolt/Screw size help
Hi All,
Starting the Vintage Air install on my 73. When i took out the original condenser a month or two ago I must have misplaced the two upper bolts and two lower screws that attached the condenser to the radiator support. Per the AIM it looks like the bolt is GM# (180086) and screw is (9420065). Been digging around online and have been unable to figure out the exact hardware to use. Looks like the bolt is 18TPI but unsure of any other details. Hope i can find suitable replacement at Home Depot or Lowes. Any insight would be greatly appreciated!
Old Nov 15, 2020 | 12:55 PM
Mooser's Avatar
Mooser
180086 BOLT,Hex, 5/16" - 18 x 1 7/8", Gr 5
Regular bolt with a washer, nothing special
9420065 is a pointed self-tapping #14. 1" long with the built in flange on the hex
M
Old Nov 15, 2020 | 01:05 PM
Kev73's Avatar
Kev73
Thanks Mooser! Heading to the hardware store in a bit.
To Condenser Bolt/Screw size help
