Starting problem
Old Nov 23, 2020 | 08:33 PM
JAMES McGill's Avatar
JAMES McGill
1st Gear
Default Starting problem
I have a1982 collectors Edition. I have rebuilt steering colum, changed neutral safety switch. And still sometimes the car won't start. When I connect a remote starter switch it fires right up. This problem only happens sometimes. I am out of Ideas on how to repair this problem. Hoping someone else may have had similar issues.
Old Nov 24, 2020 | 12:30 AM
Haggisbash's Avatar
Haggisbash
Did you correctly set up the ignition switch so that it closes the contacts properly when the key is turned to the start position?
File Type: doc
Old Nov 25, 2020 | 10:54 PM
taylorteamracing's Avatar
taylorteamracing
make sure the slide switch is adjusted proporly sounds like it is just a hair off
To Starting problem
