Strut Rods
Old Nov 24, 2020 | 06:32 PM
mbp's Avatar
mbp
Default Strut Rods
Hello. I have some questions about strut rod bushings on a 69.The outboard bushings are showing wear and tear but the inboard bushings are in good shape? My questions are, is it usually hard to remove the old bushing that have been there for years, what is required to press in the new bushing and if only replacing the two outer bushings will an rear wheel alignment be necessary? Thanks for all assistance.
Old Nov 24, 2020 | 06:59 PM
interpon's Avatar
interpon
Not sure it’s too different than a 79 but here’s how I did mine take note of your settings but I wouldn’t worry about a rear alignment but you can do it yourself.
removing the shock support is going to be the most difficult task.
lots of great advice i got
https://www.corvetteforum.com/forums...od-advice.html
Mooser's Avatar
Mooser
Removing the bushings isn't a real problem and a press probably isn't needed... removing the shock/strut mount is usually the problem as it's bonded into the bushing sleeve on the molecular level
But hundreds or even thousands of them have been taken off and swapped out, the tool to drive the mount out without destroying the thread is a great help if they don't want to budge.
Alignment probably not needed, the change will be insignificant. If it was ok before it will be again, mark the position of the adjustment cams and put it back where it was
M
Old Nov 24, 2020 | 07:00 PM
Mooser's Avatar
Mooser
There you go, pretty much as he describes, yours will be the same basic setup
M
Old Nov 26, 2020 | 01:18 AM
kossuth's Avatar
kossuth
Depending on how attached your car is to the current strut rods have the following handy.
1. BFH
2. Air Hammer
3. HEAT
Having a tool handy to save the bolt threads is super helpful (I just put a hardened nut on the end). In my case I was replacing the strut rods (originals were bent by a bubba trying to align the car) so I just blew them off at the joint with a torch. I was only able to get one bolt out. The passenger side just would not budge. Sludge hammer, heat, air hammer, penetrating oil, nothing worked. Eventually I just blew through that bolt with a cutting torch after fighting with it for almost an hour. Sometimes they can be that stuck.
Old Nov 26, 2020 | 02:55 AM
4-vettes's Avatar
4-vettes
Cruise-In VIII Veteran
yes, those lower shock mounts can be a real bear!
Old Nov 26, 2020 | 08:12 AM
ralphspears's Avatar
ralphspears
Banned Scam/Spammer
Once you get the strut rod off put a propane torch on the old rubber bushing and heat it up it will catch on fire and fall right out
Old Nov 29, 2020 | 12:05 PM
drwet's Avatar
drwet
That would get the rubber and the inner sleeve out, but you still have to press out the outer sleeve before you press in the new bushing.
Old Nov 29, 2020 | 01:11 PM
ralphspears
Banned Scam/Spammer
There is no outer sleeve on originals. The replacements have an outer sleeve
Old Nov 29, 2020 | 01:41 PM
interpon's Avatar
interpon
correct..which is why i went usa energy poly..similiar as replacement rubber...
To Strut Rods
