Brake Booster Stops Working When Vacuum is Pulled
what I would do to check the booster is hook up a vacuum pump like a might vac and see if it holds vacuum.
I just went through a nightmare brake problem, so I have a bit of in site here.
The only tests that I know of for a booster rat home-
With the engine off, pump the brakes till you get a hard pedal. Hold pressure and start the car. The pedal should drop a bit if the booster is working correctly.
As above, apply vac to the booster to see if it holds. If it does, it is a indication that the booster is probably good. If not, definitely bad.
With the car running, if the booster is good and the pedal is soft or goes way down, you probably have air in the system that the extra power exacerbates.
After a good bleeding, i would check the master cylinder next.
On a correctly operating PB system, if the booster is bad, the brakes would still work, but with significantly harder pedal and significantly (30-40%) less braking power. PB cars have a larger mc bore which changes the dynamics a lot.
You know the booster is working properly because the pedal becomes functional. The fact that the pedal goes nearly to the floor and is 'soft' indicates that you have air in the brakes fluid system....somewhere. The brakes need to be bled to remove all air from the lines. Then you will have a good firm pedal that doesn't go to the floor.
